courtesy light stays on
Old Nov 7, 2024 | 09:29 PM
Paul Montoya's Avatar
Hello good people. I have a 1967 cutlass and the courtesy lights wont turn off. I tested the drivers door switch and its good. Im going to test the passenger side tomorrow. If both switches are good what other than a bad ground can make them not turn off? When I say bad ground Im referring to the switch being grounded to the door when tightened down
Old Nov 8, 2024 | 05:00 AM
Is the headlight switch **** turned all the way to the left?
Old Nov 8, 2024 | 10:33 AM
no sir I checked
Old Nov 8, 2024 | 10:49 AM
fleming442's Avatar
There's a white wire grounded somewhere. Retrace your actions. You either pinched it somewhere, or the wire is loose in a door jamb, under the dash, etc, grounding out. Headlight switch could be bad; unplug it, and see if the light goes out.
Old Nov 8, 2024 | 11:25 PM
i found out the switch is bad. Thank you for you help
Old Nov 9, 2024 | 04:59 AM
Which one?
rand5204
Dec 24, 2019 06:17 AM
Dadsbadass442
May 1, 2018 05:35 AM
deaddds
Apr 1, 2018 06:48 PM
rctoyguy
Dec 19, 2014 04:28 AM
craftsmen22
Jul 26, 2010 03:32 PM
