Trunk release ckt for 67 442
Old Sep 29, 2024 | 11:56 AM
bonanzaman's Avatar
Hi, I have a 67 442 convertible and my trunk release stopped releasing. It's vacuum operated with a button in the glovebox to actuate it.
Is there any circuit diagrams for this, i've looked in my manuals and see nothing. It was working a few weeks ago but stoipped.
Dave
Old Sep 29, 2024 | 01:25 PM
nicks1966's Avatar
Did you check to make sure you have vacuum at the glove box and at the actuator on the deck lid.
The system is very simple, vacuum hose from engine to vacuum canister, hose from canister to glove box switch and hose from glove box to trunk.
here is a picture of the routing, it's in section 15 of the chassis service manual
Old Sep 29, 2024 | 01:30 PM
bonanzaman's Avatar
Thanks, I looked for that and could not find it. I'll check it out!!
Dave
Old Sep 29, 2024 | 02:16 PM
It's really not much of a "circuit". The actuator at the trunk latch has a piston that pulls the latch when vacuum is applied. There's a hose that runs to the button in the glovebox, which is a normally-closed valve that opens when you press it. Opening that valve connects the hose from the trunk actuator to engine vacuum. The vacuum ball is simply a storage space so the release works once after the engine is turned off.
Old Sep 29, 2024 | 03:30 PM
bonanzaman's Avatar
Thanks, got it fixed.
first442
Mar 27, 2022 09:06 AM
Goldiewilson4mayor
May 17, 2020 06:26 PM
pizzyp
Nov 17, 2014 01:39 PM
jag1886
Feb 11, 2014 04:24 PM
Olds luvr
Jan 26, 2009 08:24 AM
