PDA
View Full Version : 442
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12
  1. 66/67 with G70-14
  2. Throttle linkage throw length.67 442 automatic
  3. Underside Finishes
  4. 71 W-30? On The 'Bay - Window Sticker Suspect
  5. What Gives Here?
  6. SSll bezels
  7. Auto seat cover kits.
  8. 1974 SSll / SSlll 15 inch wheels
  9. Sound deadener
  10. 1966 4-4-2 hood trim
  11. Bumpers
  12. Dr. Olds wall mural
  13. Pertronix ignition and factory tach on 71 442
  14. Choke Ideas for a 68 442 with Edelbrock intake
  15. Are These nos GM W30 Hood Latches?
  16. Efi
  17. 1971 442 Convertible
  18. Fremont Built '67 442 Verification question
  19. '67 442 stick California car
  20. Rear side windows mechanism
  21. 1968 post coupe quarter glass seals
  22. 1967 Fremont 442 Protect-o-plate decode
  23. 1967 442 Protect-o-plate question
  24. 1971 442 Convertible
  25. Air cleaner assembly
  26. 65 442 fan clutch
  27. Dark clock in tach on 71 442.
  28. 1970 442 fan blade
  29. 65 442 upper radiator hose recommendation
  30. Converting shifter
  31. 70 W30 Power Seat Motor
  32. Headers
  33. Calling All Skilled Troubleshooters - PLEASE HELP!
  34. 1970 442 - Volo - Need Input
  35. 1967 oldsmobile cowl tag
  36. Tach not Working
  37. '67 442 Exhaust Tips
  38. 1968 hood adjustment
  39. '67 442 Manual Antenna Mast Replacement
  40. 68 442 trunk emblems
  41. 1968 Olds Engine Paint Process
  42. 68 442 coupe vinyl top stud template/measurements for spacing
  43. 69 455 Fuel Pump and Vapor Return
  44. Tail light Trim Color
  45. Seeking Whereabouts of 1966 Oldsmobile 4-4-2 Holiday Coupe, VIN 338176M214264
  46. 1966-67 442 console tachometer retro fit
  47. F heads for 70 442
  48. Removing convertible. Top pump in 71 442.
  49. '69 Olds H/O 455 4v valve train
  50. 67 442 Bench Seat Headrests
  51. Trunk lids
  52. '67 442 Distributor Screw-Up
  53. Recently Acquired this 1967 442
  54. Throttle Stop Solenoid
  55. 1972 cutlasss/442 Which style keys work with which locks
  56. '67 442 Remote Mirror - Crazy Idea
  57. 1971 442 I May Purchase- What do You Think?
  58. 1967 442 Wheel/Tire Opinions
  59. Production Period for 68 442
  60. 67 442 Installed new upper A arm rubbers
  61. 67 New Fuel Pump Fitment issue
  62. Looking for guidance
  63. 1968 442 door panels
  64. 1965 442 Steering Wheel Cap
  65. These Nuts
  66. OPG front inner fender
  67. Specification help from a noob
  68. Identification help on 68 442
  69. 67 w30 red inner fender panels
  70. Convertible question...
  71. OAI Air Cleaner Help
  72. 67 442 with HEI
  73. 442 fender numbers
  74. 68 442 Fuel Starvation
  75. 1972 442 W-30 Cowl Tag Decode
  76. W31 convertible production numbers
  77. Trim color number
  78. Vacuum lines help
  79. Radiator Cap 67 442
  80. Quadrajet carb missing clip on inlet needle
  81. Lower radiator hose spec..
  82. New car added to the herd ...need ID assistance
  83. Rad seal...
  84. Looking for Restoration Shop
  85. Torque converter 442 or w34 tornado
  86. Top plate measurement...
  87. 1966 442 header recommendations
  88. 1976 77 442 - Is there a VIN Code Identifier?
  89. 5V Designation on Car ID Plate
  90. 1970 442 Shoulder Belt Model #
  91. Anyone know cam specs at .050 lift
  92. W30 red inner fender color
  93. 1969 radiator
  94. Water pump number..
  95. Cutlas Trim Tag Help
  96. 442 with Cutlass S trim tag
  97. Legit trans stamp?
  98. Radiator position...
  99. 1969 Oldsmobile Body Tag Decode Please
  100. Power top not closing...
  101. Looking to put a value to a 7029253 carb
  102. The score of the day. 7040256 carb
  103. 1970 442 AC/AT correct quadrajet number
  104. 1970 442 - 3.91 Only W-30?
  105. Rear light question
  106. Ram Air hood lock will not release
  107. Fan question...
  108. 67ish 442 air cleaner?
  109. 1972 Cutlass 442 shakedown cruises
  110. Another Return Fuel Line Question
  111. 1970 442 carb trouble (with glamour shot)
  112. Transmission says, "nope!"
  113. Winner of the worst 1968 Fender stripes....
  114. Instrument Cluster Bulbs
  115. 1967 Olds 442 - Right Side Mirror
  116. 1970 442 Cars Magazine Test Car - The Real Deal
  117. 1968 442 Fluids
  118. 1971 442 W30 questions
  119. 68 442 front Lower Control Arms
  120. Eddie Motorsports issues with billet hood hinges.
  121. OAI air cleaner/flapper connection and function questions
  122. 1967 Holiday coupe
  123. 1968 Olds 442 Tranny Serial Number
  124. Help decoding cowl tag 66 442
  125. Air duct missing ...
  126. Brake Pedal Return Spring
  127. 1968 442 for sale
  128. 1966 442 2 speed convedrtible with AC
  129. Fuel tank hoses/vent
  130. Radiator..
  131. Window sticker
  132. W car stripe termination in door jam
  133. 1971 442 Axle Ratios
  134. Steering column
  135. 67 442 Rally Pac Assembly Ballpark Value
  136. 1970 hurst dual shifter balls
  137. 1970 Olds 442 "shed find"
  138. Chrome Quarter Extensions??
  139. Batterie
  140. Another what is stamp mean thread
  141. Carb choke tubes..
  142. Convertible top pivot bolts
  143. 1970 W-30 distributer.
  144. 65 Trunk
  145. 1969 442 radiator hose?
  146. 1968 442 parts Identification
  147. 1965 4 Speed Console
  148. Newbie Question
  149. 1972 442 radio options
  150. JUst an update on the 71 Cutlass Supreme I looked at
  151. Verification via VIN it's a 442
  152. Trying to solve mysteries of my grandma’s 69 442
  153. All original '68 442 rust bucket ... price?
  154. 69 442 Convertible
  155. Correct inner wheelhouse finish
  156. '66 442 front fenders
  157. Sport Coupe and Sport mirrors and vent window?
  158. 1970 442 W30
  159. Looking to purchase a 67 442 question
  160. Did the 72 442 come with a 350 engine?
  161. 1970 442 door decals
  162. Build date on my 70 442
  163. Fremont 67 442 Convertible
  164. 1968 Triple Black Convertible 442
  165. Fremont 442 Convertible Cowl tag
  166. Chassis Question
  167. Washer bottle screws on 71 olds
  168. 1971 442 W-30 Convertible - Decoding Help
  169. 1966 L-69 Convertible/ Mecum Vegas
  170. Need help with cowl tag 67 442
  171. 87 442 for sale
  172. Decoding 71 442 conv. please...
  173. Rochester carburator question..
  174. 442 body panel interchangeability?
  175. New car I bought this week
  176. 72 Cutlass temp gauge firewall access?
  177. Absolutely gorgeous!!
  178. Brake booster..
  179. Rear axle..
  180. Power steering hose..
  181. Correct battery topper
  182. Heater Control Valve
  183. w27 cover bolts
  184. 1967 442 Sudden loss of oil pressure
  185. 67 442 Late Automatic Air Cleaner pictures and measurements.
  186. Need a power steering pump for 64 F85
  187. 70 442 4speed carburetor replacement advice
  188. Hi Looking for a carb fits 70 442 4speed car is all stock
  189. Carburator question
  190. 65 442 value
  191. 442 with headers
  192. Flat washer AND lock bracket for 1967 Exhaust Manifold?
  193. 1968 post coupe molding clips
  194. 72 Hood Hinge Springs
  195. 72 Hood Hinges
  196. 1971 442 Convertible Hood Stripe
  197. Help decoding 1968 engine code and verifying if 442?
  198. 1972 442 correct hood hinge springs
  199. 65 442 and Trans Swap
  200. 1st car after getting married.
  201. POP Decoding
  202. 1967 Olds gas cap
  203. Cowl Tag Indentification
  204. Cowl Tag Help
  205. 72 442 clutch replacement
  206. 70-72 door stamping differences?
  207. Overheating issue with my 1966 442
  208. Transmission pan
  209. Pictures vs. Photographs
  210. Neutral start switch
  211. 72 Olds Vin Decode
  212. Hood hinge color
  213. can anyone tell me about trim code Z?
  214. Center Link Rubbing Cross Member?
  215. How many ?
  216. 1969 442 glove box door adjustment
  217. Leno and Osborne Drive A Muscle Car
  218. Title/VIN history
  219. Underhood insulation
  220. How are trumpet exhaust tips attached?
  221. Pictures for dual gate cutout
  222. 69 442 Convertible Rear Cross Member Question
  223. 71 Positive battery cable install
  224. Two '77 442's for sale in Texas
  225. 1964 steering wheel install
  226. Special order paint color?
  227. 442 w 30 stripe question
  228. 69 442 steering column lock plate
  229. 71 496 stroker Howard roller
  230. Correct air filter
  231. 1966 L69 Tach Question
  232. Color change ethic
  233. Original w25 hood
  234. Factory differential for 70 W-30
  235. 1966 442 Tach (on console) wiring schematic
  236. Reverse lock out question in a 1970
  237. 1970 W-30 distributor date code info
  238. Original 1970 Oldsmobile 442 floor mats
  239. Door jamb decals
  240. Engine stamp decode info
  241. Battery drain when car is off question
  242. Photo
  243. Date on cowl tag?
  244. Column shifted/bench 442 opinions .
  245. Anyone put Eddie Motorsports billet hood hinges on a Ram Air hood?
  246. 72 442 convertable top pump replacement
  247. A/C line to orfice
  248. Headliner Trim at Windshield Installation
  249. Tail pipes
  250. 69 W-30 on MuscleCar TV
