PDA
View Full Version : 442
Pages : 1 2 3 4 [5] 6 7 8 9 10 11
  1. Weatherstrip Installation
  2. Weatherstripping for '68 442 convertible
  3. Fuel Sending unit wire route..
  4. w-30 painted
  5. 65 steering column
  6. Broken spring on hood latch. 68' 442
  7. Early 442 on eBay
  8. Radiator shroud which is correct for '68 442
  9. Noob here. Need help with a fuel issue.
  10. 1968 steering column tree to floor conversion....
  11. Weird Carb Things
  12. The CORRECT 2nd Style 1970 Tire Pressure Decal Available From Ray Derise - CO Member
  13. Odd OE Fastener Pic Needed For 70 442 - 406175
  14. Heat Insulating Material Question
  15. 65 442 Hot Starting Problem Ponderance
  16. 1965 442 Throttle Linkage Question
  17. Which Clips / fasteners for trunk emblem
  18. 1977 Cutlass / 442 wheel well moldings the same?
  19. 68 400 distributor upgrade options?
  20. Value 1973 442?
  21. Same Starter Issues As Last Year
  22. 1965 442 Back In The Game
  23. Swapping steering column column shift to floor on '68
  24. End Build Date 3/72 for 1972 W-30's
  25. 1972 Model Year - Rear Spoiler Option?
  26. Recommended engine oil for 455 Rocket
  27. Question on 1965 4-4-2
  28. Jack stowage
  29. Power brakes available on '68 442 4-speed?
  30. Starter ID delco remy 1108371 correct for my '68 442?
  31. Just bought a 1970 442 tell me what I have.
  32. Interior change out question
  33. Just found 1966 442 but have a question
  34. Just adopted a 68 442
  35. Other cool Olds sightings auction week in AZ
  36. Glove box light escutcheon, nut
  37. Another interesting Olds at Russo and Steele
  38. 1969 442 Sports Coupeople I.d help
  39. Fan Shroud - do cutlass w/ac and 442 use same shroud?
  40. Headlight housing, front bumper removal '68 convertible
  41. Comments/questions from non-442 literate people
  42. Data plate
  43. A/C availability on '68 convertible
  44. title questions GA
  45. 1968 442 questions
  46. How many 70 post coupe w-30's
  47. Looking for a little help...
  48. 72 442 vert - broadcast decode
  49. Glove box light
  50. W30 brake question...
  51. torsion bar install
  52. Swapping Ac for Non AC equipment…. what am i missing
  53. simple green- strips paint and rust?
  54. Parking brake bracket
  55. How many '68 W-30 Posts?
  56. The Art Of Being Stupid
  57. 68 442 convertable suspension
  58. Kick panel removal '68 442 Convertilbe
  59. Bumpers, grille, headlight doors '68 442 convertible
  60. Courtresy lights fuse '68 442
  61. Gauge bulb replacement
  62. Bulb replacement rear armrest
  63. 442 and Jetaway
  64. 1965 442 4 Speed Conversion
  65. tune up specs
  66. 5v on 67 supreme data plate 442?
  67. Two tone seats and door panels 1967
  68. removal of inner fender
  69. Picture of original factory antenna for '68 442
  70. Heater core replacement
  71. 1969 442 Wheel/Striping Questions
  72. Some opinions
  73. Which master cylinder is correct?
  74. Please help to decode
  75. Drain plug location on '68 4-speed trans
  76. How can i decode this
  77. Was there a super stock 4 on a '71 442? (See picture
  78. What's it worth and what do I need to know.
  79. Possible 442 in wrecking yard?
  80. Bumper guard location- 1971
  81. 68 OAI scoop questions
  82. AC compressor and normal operating temp
  83. 68 442 4-core radiator
  84. Engine pad
  85. '68 442 clutch equalizer / Z-bar Help
  86. 67 442 cowl tag
  87. Air cleaner
  88. 67 442
  89. Hood lock? Is it just a pad lock?
  90. W30
  91. Power steering belt issue
  92. 69 442 trunk stripes
  93. 1969 442 W30 (maybe)
  94. Hood & Trunk 68
  95. Special Olds Viewing
  96. 1973 442 wheel & tire OPTIONS
  97. dash pin stripes 1968 442
  98. Advice for a friend ..
  99. Chrome Moulding Question
  100. 7029253 carb WIW?
  101. Help with value of 1970 4-4-2 Sports Coupe
  102. First 1964 442 Magazine Ad
  103. Fuel tank sending unit adjustment
  104. 71 W30 Auto Carb 4 speed in an A/T
  105. 1971 Olds 442 Lime Green Convertible w/ Pearl Pictures
  106. 1970 442 production
  107. Gas tank ofr '68 convertible
  108. Rear wheel well housing
  109. Cooling system '69 442
  110. 68 442 underbody color
  111. upper radiator top
  112. Buyer Beware Game
  113. Carburetor help please
  114. 71 OAI intake manifold setup
  115. W30 Steering wheel
  116. Shifter cable question?
  117. Coil number?
  118. patch panels for '68 442
  119. 1966 Cutlass 455/400 swap
  120. 1965 442 Finally Roadworthy...Sort of !!
  121. Mufflers for '68 442 conv.
  122. 1970 442 Window Trim
  123. 68 442 fuel tank vent
  124. 68 W30 caburetor useage 7028251 7018254
  125. Original OW Bellhousing Marking - What is the "4" For?
  126. Radiator core support/hood interchange 69-70?
  127. 69 442 w30
  128. Difficult To Find Parts For 68-72
  129. Young Newbie to Oldsmobiles!
  130. plug wires for olds 400 cu.in
  131. Robski's 65 442 Post in 1972
  132. All ready for 9 day Oregon tour
  133. Tire question
  134. '72 Convertible 442 possibly for sale
  135. '77 Olds 442 w/350 Question Advise Etc..
  136. A little detailing while recovering from the 4th
  137. 442 bumper
  138. Value of low miles, low option 1970 442
  139. Newbie looking at a 68 Olds 442
  140. OAI Assembly
  141. 455-400 Linkage Difference?
  142. New to me 1972 442 Convertible, Ram Air 455
  143. 1965 442 Bracket Question
  144. 1968 442 bumpers
  145. 69' 442 Gear advice
  146. 71' 442 Help
  147. 70 W-30 color combo
  148. impossible task...
  149. '68 442 Question?
  150. ram air breather
  151. 1971 w30 question
  152. Exhaust options
  153. Great Site
  154. 68 442 Post 2 door coupe
  155. Vin #s
  156. How to tell a 442
  157. coolant decal location for 70 442
  158. '68 442 spare?
  159. W30 camshaft specs.
  160. Driveshaft / yoke orientation?
  161. Exhaust manifold heat shroud-how to install
  162. Website
  163. restoration kit?
  164. Fuel Pump Advice
  165. 1970 W30 carburetor jet size
  166. What Is This Thing Off My A/C Condenser On A 70 442?
  167. Tail light bezels
  168. Rear Quarter Trim '68 Cutlass Conv…..how do i ship these things?
  169. 1966 at Mecum
  170. This guy did not know what he owns
  171. 68 442 bumpers
  172. 1972 4-4-2 questions
  173. Need Photos and # or original Radiator caps 65-67
  174. 69 Cowl tag decode
  175. 64 442 Question
  176. 442 stands for ?
  177. Ongoing 65 442 Saga
  178. Need help locating parts for my 1987 Salon
  179. WTB - Thermostat housing 1972
  180. 67 convertible rear window replacement
  181. Need Help decoding Protecto Plate 1966 442
  182. Rough Valuation Needed Please - 70 442 Vert
  183. Help with rust
  184. 1967 442 post coupe
  185. 1966 442 spare tire storage sticker question
  186. 68 442 interior armrest
  187. Need help locating 442 emblem mounting holes for a 1968
  188. 70-72 Ram Air Hood Fitment Question
  189. Ss1
  190. How many 1969 442 convertible 4 speeds were made?
  191. How do I know if a 72 442 is a true 442 and not a clone?
  192. trunk paint
  193. Sad way to go
  194. W45, w46 ?
  195. Please Help - 70 442 Questions
  196. 68 442 headlight buckets
  197. Z Trim Clue - Factory Assembly N or Z Marking On a 70 442 Column
  198. 1971 442 convertible - NON W30
  199. 1965 442 rear seat belts
  200. feul injection
  201. Help
  202. 1969 442 cam replacement
  203. 68 442 rear view mirror questions
  204. Templet for trunk lid 442 emblem holes?
  205. air cleaner paint
  206. Paint
  207. Clean, Husky and Handsome!
  208. 1971 W30 value?
  209. Real Factory Pilot or?
  210. Trying To Reuse The Original Bumper Fillers - How Do They Look To You?
  211. Header recommendation
  212. Purpose of vacuum operated OAI
  213. Color of bumper jack parts??
  214. 1970 442 engine compartment detailing photos
  215. 1971 442 Fender question
  216. Another inspection
  217. 68 442 dash and body stripe....
  218. Radiator closest to OEM type
  219. is fake or real documents
  220. 67 cutlass 442 rear seat question
  221. '73 V Code (455/M20) 442 on Ebay
  222. Windshield on '68 442- are hardtop and convert the same?
  223. Springs once again 66 442 conv
  224. 70 W-30 Hood Marking - Is This Original?
  225. 69 442 ??????????????????
  226. Correct Fastener Pic For 70 442
  227. Your opinions please
  228. Inspection
  229. 1975 Cutlass Salon S 442
  230. vinyl cover material for '68 442 convertible windshield header….
  231. 1965 Olds 442 Throttle Linkage
  232. 68 cowl tag decode
  233. Bolts and Nuts or bumper brackets- black?
  234. W30 question
  235. Glove box
  236. Decode
  237. 1970 W-30's For Sale tomorrow at Mecums
  238. Grille repair 1968 442….
  239. 70 442 W-30 Replica
  240. 68 442 hood inserts
  241. Inspection
  242. speaker hole
  243. What is correct valve cover color?
  244. Finally got my 75 442 running carb question
  245. Correct style high pressure power steering hose '70
  246. In the dark..
  247. 69w30
  248. Window Exterior Fuzzies
  249. 67 w30
  250. 67 442 conv. trim tag. ID Fremont car
