- 70 442 matching # engine importance
- 1987 442 RPO codes
- 1970 pace car decal removal
- Trim Tag Help!
- 1986 442
- 68 442 Radiator Seals
- Outside Air Ind VS Rain
- 1968 w 30 442 red front wheel wells
- Power Steering Pump Bracket 71 442 455
- How do I find out how many made
- Parts compatible?
- 70 442 Bumpers
- I got it.
- turn signal switch not cancelling
- My 442
- Cowl Tag Help
- 70 Rallye Olds
- How to clean out differential?
- Proper gear lube for differential?
- 66 442 Fuel Line Question
- 68 442 vert steering wheel
- 66 442 Flywheel Question
- 1966 fender vent/scoop paint detail
- Molding identification
- 7040258 (70 W30 Auto) Date Codes vs Vehicle Build Date
- 1968 442 Trim Code 949
- Seeking Owner of a 1966 442 Holiday Coupe VIN 338176M214264
- 66 442
- 1971 442 oil pan removal
- 1970 442 in Utah or N.Arizona
- OAI diagram help
- '70 442 Dome Light Fixture
- hood stripes
- PerTronix Ignitor vs Ignitor II and III
- broken studs; need new hub... where to buy?
- W 30??
- Original gas cap
- 69 442 Interior
- 1968 442 convertible cowl decode
- New tires and a repaired radiator on our W30
- '76 442 Broadcast Sheet found!
- New Floor Pan Question
- 1970 442 convertible restoration pics
- may be purchasing, need help asap
- 70/71 power window door panels
- 1970 442 W30 Barn Find
- Which muffler should I use?
- Maplight rear view mirror
- 1970 pace car cowl tag
- How to Replace Heater Core?
- 1965 Oldsmobile 442 project
- Need engine mounts
- 1970/1971 442 engine pad stamp
- Exterior Temp Indicator
- 67 442 Trim
- I need an oil filter housing gasket
- What temp thermostat should the 455 use?
- '70 original ignition coil markings for the 455?
- Interior bulbs
- I need a vacuum diagram.
- Which headers should I use?
- Dual gate question.
- rear end dilemma
- First Cutlass 442
- PCV to carb question
- ExhaustHeaders for 330 small block
- 1968 olds 442 post value stock or mods
- 65 442 EMBLEMS from PARTS PLACE
- Today was a good day
- What should a complete set of rally pac gauges go for?
- Post Window Trim
- Looking for a Car and a Person
- 68-69 OAI Hood Insulation Delete
- Windshield source?
- Stupid 442 shifter question ?
- 65 442 Fender Moulding Access
- where can i find the vin# on my dads 69 442 ?
- what motor oil to run
- Pulling '68 442 engine
- 1970 442
- Number of stick shift '69 442 post tops?
- 72 Convertible Stripes
- Can anyone Identify these 2 parts?
- pro street 1970 442 w30 pics (miss my car)
- VIN factory mistake or wrong?
- '70 442 #1 indy pace car story with photos
- help decode the vin (1970 442) please
- 86 442 not sitting level
- Early 72 442 cars
- Another 72 442 documentation question
- Hood ground straps
- 1970 442 Identification
- Length of Hose?
- body mounts, replace or reuse?
- Switching to a 4speed
- 1966 or 1967 Radiator Top Plate
- Batteries
- Identify this carb please....
- need a 1968 442 grill
- My 442 Pictures in the
- Need wiring diagram for 68 442
- 1971 442 fender question
- 66 L-69 Tri-Carb Id, PVC, Power brake vac
- How do I identify the correct radiator for a 1971 442 ?
- Toro vs. 442 Quadrajet Differences Need Advice...
- Drove the 442 vert. to the Daytona 24 (pics)
- 68 442 engine rebuild options
- Open Face Alternators and 442/W30s
- What master cylinder is correct for a 71 W-30 with MANUAL disc?
- Help Identify!
- blower not working
- Weight of a stripped down 442?
- Making a Tribute
- Replacing the doors on a '71 442
- Carb Re-build Question
- Looking up block and vehicle numbers
- 1972 w30 heads
- Omned 66 442 for 28 yrs
- Factory interior color or...
- Mufflers for stock W-30
- 67 "O" Axle
- book recomendations?
- Switch Pitch Photo's and Operation
- Oil fill tube decal
- Help for 1987 442--air filter
- Points to electronic ignition coil voltage
- 1968 w30 air conditioning?
- 69 442 with blower
- 1968 w-30 broadcast sheet
- 64 through 66 console mounted vacuum gauge
- 1968 w-30 convertible
- Hog-ringed tags attached to seats
- vin location
- Gas tank pad?
- Anyone know this car?
- Maybe I found it...
- Earliest built 1970 442 & W30
- 66 442 tail light bezels
- Hog ringed tag in back seat
- couple of questions and a pic..
- What color stripes ?
- Last 1972 W30 built??
- VIN # history
- 400ci - '65-'67 / '68-69
- Tire size for 15x7 SSI wheels?
- Was leather interior an option?
- Pretty nice for the money!
- EBAY WARNING - BEWARE oldsfreddy
- Concept 442
- mufflers for 68 big block
- question on pcv and breather on a 66 442
- 1973 Hurst Olds
- NOS Fender Part Number Help
- 70 power trunk release and lock question
- Under Hood Light '70 442
- 72 442 build sheet.
- What size wheels ?
- 442 stripes or decals or leave it alone ?
- Who knows something on the 1967 Hurst Hustler?
- Any Exhaust recommendations?
- Another cowl tag to decipher
- Anyone know anything about this 1970 W30?
- 1967 Pin stripes. Y70
- I Blew My Motor Up - Motor Question
- W-43 The Olds That Never Was
- help idenifying this 1969 442 W3O car please
- Factory disc brakes on a '67 442
- 1969 442 convertible....how many were made like this??
- 455 big block question
- Official 1970 Indy Pace Car is heading WEST!
- Red line tires on a 1969 442 W-30
- Is it a 442 or not ??
- Plastic Chrome Plater - Chrometech
- New Member - Looking at a 70 442 for sale
- w-25 hoods and low tension hood springs
- What is correct radiator for a 71 W-30
- Wanted: 1986 442 front driver fender
- Pin Stripping 1971 442
- Removing Anodization
- '68 442 - Color Surrounding Taillights
- 68' 442!
- '68 442 steering wheel
- Fuel filter
- SSIV Wheels On An A-Body?
- How can I tell if the odometer is the actual reading? HELP!
- Need your experience
- 1971 rear wheel HP
- 68 442 Rad Support
- 70 442 Dash Question
- My new 1991 Calais 442 W41!
- 70 442, comments? can anyone decode the body tag?
- Any experience with this header?
- Determining 442 color/options rarity - 1971
- Thermostat
- Alternator Amperage ?
- Trim Plate Question
- Where to place amp?
- eaton possi differentail
- 1967 442 info
- '68 442 Handling
- OE tires for a '67 442
- instrument panel
- Questions about my 72 w30
- 1969 442/cutlass s brake problems
- Fire Extinguisher mounting bracket
- Trunk molding
- 72' 442 opions package?
- 1968 442 front wheel drive ???
- Exhaust-Trumpets and stuff! for 69
- upper lower control arms
- 442 appearance
- Air Cleaner
- High Beam Bulbs
- gears
- steering box
- 70 442 Carb Info
- 1967 W-30... thoughts?
- 68 442 console lid/ how to?
- 1970 Indy Pace Car 442 w-30 goes to Eyes on Design 2011
- 1970 442 w-30 goes to the Motor Muster at the HF
- '66 442 validation
- TKO in a 442
- 67 442 Qjet question
- Shake
- Need help! do you have a 1970 olds with calif emissions
- Can anybody identify this clip?
- 442 Brake booster question
- HEADERS Which Ones & Why?
- Will shaving heads change compression QUESTION
- oil filter
- Value of 1970 gauges ??
- 1968 400 ci valve covers?
- Aftermarket 69 442 hood
- 67 Side View Mirror Location?
- Carb tags
- Rochester 750 CFM.....HELP
- 1971 SS1 wheels trim ring vs. all chrome
- 1966 442 radio with rear speaker fader switch faceplate
- 1966 442 Trunk Mat what's correct?
- Which Dynomax Super Turbo Muffler?
- Name these parts
- Edelbrock Victor with OEM 68 hood?
- Carter Thermoquad on 66 442 - original?
- Official #1 Olds 442 Indy 500 pace car go on the street for the first time
- Rear quarter panel skins (source???)
- Poly engine or transmission mounts
- Opg
- ID help 1970 AM/FM
