Today was a good day
I don't see how this is a W30 from just looking at that cowl tag. The W30 option in 68 was the force air (OAI). Is there something not in the pictures to suggest it was there?
). Most importantly, note the clips on the inner fenders for holding the O.A.I. tubes. Nice find.
Not from the cowl tag, but I'm assuming the chalky white inner fenders were originally red? Note the correct passenger-side washer fluid tank, the manual drum brakes, and the CORRECTLY POSITIONED W-36 stripes (
). Most importantly, note the clips on the inner fenders for holding the O.A.I. tubes. Nice find.Could be, from what I see, the inner fenders look black, the stripes look factory so they should be ok. Did the 68 W30 have W30 just over the front marker light? I see what you mean about the clips. I didn't see them when I first looked. That's why I asked. Can you tell from the pics whether this was a 4 speed? I can't see any pedals, but maybe the console mounting bracket sticking up can give a clue? Or would you need to see the hole in the tunnel? Found this on the site that shows the detail. https://classicoldsmobile.com/forums...tml#post155936
No external W-30 decals or emblems in 1968. I tried zooming in on the firewall photo but I can't tell if there's a clutch rod cutout or not - not that it matters, you could get an AT W-30 in 68. I suspect that the black on the inner fenders might be paint. I have a red 1970 inner that someone painted black. Fortunately, once you strip the paint, you find that the paint does a good job of keeping the plastic from fading.
Thanks,I think we can save it not as bad as it looks.We have had worse come into the shop and its only metal.I have 3 68 W-30 a convertible and two hardtops.May use the white car to fix the other car???Hate to take a rare car apart but the top is gone rust.Will know more on Friday.
Which is why this part is now available as a repro:
http://www.opgi.com/p/steel-body-pan...6/CH27798.html
