Today was a good day
Old Apr 15, 2012 | 11:11 AM
slaughter442's Avatar
Found a 68 W-30 will know more on Friday when I get home.
Old Apr 15, 2012 | 01:17 PM
I don't see how this is a W30 from just looking at that cowl tag. The W30 option in 68 was the force air (OAI). Is there something not in the pictures to suggest it was there?
Old Apr 15, 2012 | 01:40 PM
Not from the cowl tag, but I'm assuming the chalky white inner fenders were originally red? Note the correct passenger-side washer fluid tank, the manual drum brakes, and the CORRECTLY POSITIONED W-36 stripes (). Most importantly, note the clips on the inner fenders for holding the O.A.I. tubes. Nice find.
Old Apr 15, 2012 | 02:42 PM
Could be, from what I see, the inner fenders look black, the stripes look factory so they should be ok. Did the 68 W30 have W30 just over the front marker light? I see what you mean about the clips. I didn't see them when I first looked. That's why I asked. Can you tell from the pics whether this was a 4 speed? I can't see any pedals, but maybe the console mounting bracket sticking up can give a clue? Or would you need to see the hole in the tunnel? Found this on the site that shows the detail. https://classicoldsmobile.com/forums...tml#post155936
Old Apr 15, 2012 | 03:01 PM
No external W-30 decals or emblems in 1968. I tried zooming in on the firewall photo but I can't tell if there's a clutch rod cutout or not - not that it matters, you could get an AT W-30 in 68. I suspect that the black on the inner fenders might be paint. I have a red 1970 inner that someone painted black. Fortunately, once you strip the paint, you find that the pls
Old Apr 15, 2012 | 03:02 PM
No external W-30 decals or emblems in 1968. I tried zooming in on the firewall photo but I can't tell if there's a clutch rod cutout or not - not that it matters, you could get an AT W-30 in 68. I suspect that the black on the inner fenders might be paint. I have a red 1970 inner that someone painted black. Fortunately, once you strip the paint, you find that the paint does a good job of keeping the plastic from fading.
Old Apr 15, 2012 | 04:38 PM
It a 4 speed posi gages no power steering or brakes with console will get better photos later .Missing the scoops and air cleaner but have them on the white car which is a W-30 auto car with rusty top.
Old Apr 15, 2012 | 05:51 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Looks pretty wasted? Hows the metal?
Old Apr 15, 2012 | 06:29 PM
4speedBench's Avatar
Man, if it can be saved...more power to you. Nice score!
Old Apr 16, 2012 | 02:18 PM
Thanks,I think we can save it not as bad as it looks.We have had worse come into the shop and its only metal.I have 3 68 W-30 a convertible and two hardtops.May use the white car to fix the other car???Hate to take a rare car apart but the top is gone rust.Will know more on Friday.
Old Apr 16, 2012 | 04:53 PM
Which is why this part is now available as a repro:
http://www.opgi.com/p/steel-body-pan...6/CH27798.html
Old Apr 17, 2012 | 04:03 AM
Thanks Joe I will look into that.Has any body used this roof??I like to use good old GM but Goodmark is getting better we use their floor pans.Thanks for all the help and info this may help save a car or two.
Old Apr 24, 2012 | 05:53 PM
Octania's Avatar
where's the white car? Here in MI I have cars missing the bottom 10" but the roof panels are OK...
Old May 13, 2012 | 08:38 AM
That sounds good I looked at the Goodmark roof,The one they had at the show was ok but light metal and would need alot of prep work.I will let you know on the roof and thanks for the offer.I may change my MO and go with an older Oldsmobile for my next car. I have found a 1934 Olds 3 window coupe Im trying to buy, and may have to sale off my W-30 stuff to buy hate to see it go but dont have the space or money.Still up in the air what to do but the sale of all 3 cars and all parts would free up alot of space.This site is GREAT thanks for all your help and info Darren
Old May 13, 2012 | 08:48 AM
costpenn's Avatar
Is that a A/C clutch hold in relay on the passenger side fender?
Old May 13, 2012 | 08:59 AM
Yes the passenger fender is off a cutlass s car.
TK-65
May 2, 2015 09:33 PM
gearheads78
Jun 25, 2012 07:20 PM
myolds72
May 17, 2012 02:40 PM
gearheads78
Jul 17, 2011 10:09 PM
svnt442
Apr 29, 2010 07:14 PM
