- A Realiy Tough Decision To Make - Factory Mistake vs. Raising Questions On A W-30
- 1968 442 Convertible Trunk Lid Reproduction- Just received mine!
- EB Master Cylinder Code - Correct For 70?
- W & Z exhaust manifolds - are these reproductions?
- 66 442 cowl tag
- Please help body tag 66 442
- W30 Stripe Question
- 66 442 alternator bracket
- Tail lights
- 442 with buckets but no console?
- Wiw 1966 442
- 1968 442 trunk lid
- 67 442 Trim Tag
- 442 1/4 mile vs hemi road runner
- 1971 olds 442 455 engine pinging
- '71 442 outside rearview mirors
- "Rare" Options
- 458 and 442
- That W-30 sound (video)
- 1972 442 grill question
- To Rally Pack Or Not To Rally Pack - That Is The Question
- stupid question about underhood plate
- rear deck crack - fix? 70 442 convertible
- 1968-442 4spd LH Exhaust Manifold
- Kudos to Oldstata
- 70 OAI hood scoop correctness
- 68 pin stripe
- 1968 442 W36 black fender stripes - what paint?
- 1966 442 Trim
- Broadcast sheet help
- Ongoing Saga of 65 442
- 1970 442 4 speed convertible value
- 1966 442 Trim Code
- '68 442 - found VIN stamp on frame
- 69 442 for real ?
- How to know if its a true 442?
- Another incorrect VIN car
- 1966 442 rear trunk molding
- 1965 442 Dash Question
- W25 paint hood question
- 1972 W30 Carb Number
- Yellow High Beams
- 1970 442 orange/red paint name/code
- 1967 442 Jack Handle
- Engine Code Decals
- Little fun at the track
- Vinyl Top Differences - 70/71 vs 72
- Stripes for my 1975 442
- '70 W-Machine Light Weight Frames
- 1970 Factory 15" Rims/60 Series Tires
- Barn find 1969 442 convert
- 69 442 Trunk Emblem Template?
- '68 442 Ready for paint...need pics of silver cars
- Difficulty with total decode on Cowl Tag...
- 1965 442 / Cutlass Clues Wanted
- 1965 442 Ongoing Saga
- Created My Own 65 "Barn Find"
- 1966 442 400 tri-power 4speed convert. protecto plate question
- Looking for advice.
- re-uniting my 70 w-30 with original owner
- Do I have a 442 or a Cutlass?
- 1965 442 core support
- Getting ready to paint
- 1987 442 rear end
- 70 442 grills, Repop vs Original... Pictures
- New to forum, need advice on a '70 W-30 car
- New tires for my 69 442 convertible
- 1972 w-30
- 86 442 455 Swap
- Starting engine after 30 years
- 1965 442 advice
- just bought 1972 w-30
- 70 W30 polished up!
- W-27 Cover - Real or Repop?
- 1970 Production Figures
- I think I have a problem with my 455
- Drip Edge cleaned up, undercarriage too...70 W30
- How many 1970 442 Convertibles with 4 speed and value?
- Door lock hardware
- Relaxing admiring the "W30"!
- 1968 442 Documentation - a little help decoding...
- My 69 442 Came home.
- 70 W30 Rear Springs.. Finally
- 1968-69 Cutlass Vs. 1970-72 Cutlass
- 14x6 rims available in 66 on 4-4-2?
- Inner Fenders
- Hurst dual gate shifter
- my 67 442 conv.
- Broadcast Sheets
- 442 Vin's
- 455 headers vs stock manifolds
- TVS testing
- 70 442 w-30 Convertible resto
- 1966 442 cowl tag decode help
- 65 400 Oil Dipstick
- Any pics of 1968 442 restored in Juneau Gray
- Lucky find & buy yet again! 1968 olds 442 Turnpike Cruiser?
- Just got my '68 442
- Dual Gate Mount Location
- Mufflers for Factory 2 1/4" Exhaust
- 85 442 Canadian Export Complete Frame Off build
- Finally got some pics of my 75 442
- Plastic liner behind rear interior arm rest / qtr panels
- Any experience w/repop convertible decklids from ebay?
- 1972 Cutlass with Ram Air Hood and OAI
- Console Tach Wiring
- My Dad's 1970 442 w30
- 77, 442 Manual Shift?
- 342 gear for a 1970 442
- Help on a '71 442 value
- 1972 442 w30 X code
- 1986 442 replacement door tags
- Where did these wheels come from?
- help me save my Grandfathers 442
- 1968 442 Exhaust Choices
- '69 442 Cowl tag help
- Brakes hub without rotor
- W-30 carb help
- 1967 442 , Convertible
- Hood Stripes
- 70 W-30 convertible - Ebay
- "Factory correct"
- 1968 442 Convertible...it's ugly and it's coming home soon
- Cowl tag 442 -69
- 69 442 W 30 engine fan ??
- Engine Advice
- Rallye Pac question
- 1967 442 Engine Fan
- Remember that $300k+ W-30 rag at Scottsdale?
- 1967 442 Wood Steering Wheel
- 1971 442 Hood louvers
- Automatic transmission 1970 442
- Gawd-awful '69 on eBay
- 1969 442 disc brake master cylinder???
- console color and steering column question
- Correct code for 65 or 66 14x6 rims
- Need some info on 75 Olds 442
- help..68 442 exhaust....
- 70 OAI hood difference
- SO now we have a '77.....
- NOS Fuel Pump Question?
- How do you remove the dash light by the door?
- Where to look for a build sheet in Freemont, CA car.
- A Pic of my first Olds
- edelbrock 2151 & 1411
- Removing paint from red inner fenders?
- Need help Deciphering a 68 442 Cowl Tag
- Need help deciphering cowl tag
- 70 W-30 Radiator application?
- Optional wood insert 1966 wheel
- 70 deluxe seat belt retractor covers
- 1972 442 w-30
- 442 rad over flow can?
- Whats It Worth? 69 442
- Advice / Value 1970 442 W-30
- Earliest built 1971 W30
- Putting on the brakes!
- I need a measurement
- 69 442 4 speed ?
- What is this mounted on the inner fender?
- Starting another L69 restore
- w machine registry still up ?
- What is the most complete book on the 69 442
- 69 442 w 30 ?
- 442s only from Lansing?
- More '72 442 Questions
- 69 442 post
- Recovered Seats and cleaned interior
- Rev Limiter setting suggestions?
- Rear Wheel Well Undercoating
- Replacing Bushings & Shocks - looking brand and type preferences/recommendations?
- Just curious, was there a W-34 ?
- Need to find a Fuel Sending Unit for my 67 442
- My Craigslist Find
- Need measurements on original-type non-OIA Air cleaner for '69 Olds 442
- Tail Light Grommets?
- OAI PVC Kit 1971
- 1965 442 Saga Continues
- What happened to the 69 olds web page and more 69 442 ?
- 344.....
- 69 442 ???
- Heater quit working
- 70 442 choke heater tube in manifold p/n interchange ?
- Decoding 1964 442 convertible cowl tag
- 1986 headlights and grille fit into 1987
- 1968 w30
- 1970 442 w30
- Are these Q-Jets anything special?
- 1970 442 Bucket Seat Disassembly
- 1969 442 & Willy Drag Race
- Removing back panel on bucket seats
- Have a 69 Olds 442-Need pixs of original side mirror and Air cleaner
- 66 cowl tag
- Olds A Body 1971 Vs. 1972 Differences
- Fuel pump
- tach wiring
- Acceptable Modifications for a Muscle Car Restoration?
- 442 key #'s
- '69 442 post coupe decals
- How's it sound? Feels like progress - '70 W30
- Pics of '72 442 W30
- Replaced Ignition lock, won't turn back to lock
- 1971 442 W-30 Tribute (Not mine CL)
- Door Hinge Rebuild - Comments/Questions
- Great Electrical Vendor
- 1970 O.A.I. hood identifying marks?
- 72 442 questions
- Considerign purchasing 1970 442 convertable
- Original spare pic
- Electrical Problem with my 1970 442 W-30
- Just bought a 65 442
- Puzzled! Any suggestions?
- 77 442 junk yard find.
- Proper tip depth on exhaust??
- 67' 442 Sport Coupe
- 1969 442 W-30 Convertible
- 66 Olds 442 Post 4 SPEED BARN FIND 77K ORIGINAL MILES NEEDS RESTORED
- 70-72 Fender Brace Question
- Amost freezing here
- 73 442
- Paint floor mats
- 70' 442 w30
- 67 w30
- Who has a 1967 with cruise control or 3U on body tag?
- 68 442 w30
- '66 442 Engine Code
- 69 442
- Floor heat dampness
- R&R Radiator - Top Shelf!!!!
- Convertible roof rail adjustment 69 442
- 1971 442
- Problems starting from a stop
- Who is a good source for 87 442 parts?
- Ignition won't turn back to accessory
- Ongoing 65 442 Saga
- 67 442 Rear Glass Clips??
- 1977 442
- 70 442 "sloppy steering" remedy
- 1970 442 E heads
- where to buy good/fair price floor and trunk pans??
- Run 'em or store 'em?
- Jet's 442 (The Brick)
- Somehow I wound up with it so then I wound up here
- Bracket on frame???
- 1965 442 Work In Progress
- 70 442 power door lock wiring with power windows
- 70 pace car "hurst emblem"
- Should this car be saved or Recycled
- 1965 442
- 70 442 matching # engine importance
