Are these Q-Jets anything special?
Old Jan 9, 2013 | 03:14 PM
hadafew's Avatar
Smile Are these Q-Jets anything special?
I have 2 Q-Jet carbs in a box that make me think there was a reason for keeping them, but not sure if they are anything special. Can you fellows with the numbers tell me? I was working on '71-'72 A body cars at the time. One has a note that I had bushed the shafts to close up the loose fit, and it is numbered;
7040253 UC
0360
The other is just as removed I suspect, so why keep it? Numbered:
7040258
3366 (very light stamp here)
Thanks for any help, KC
Old Jan 9, 2013 | 04:11 PM
stevengerard's Avatar
7040253 UC
0360
7040258
258 is for an auto W30
3366 is not the number that should be on it, maybe its a replacement car come to think of it - as that translates to 336 day of 1976
253 is for a 4-speed 442
36th day of 1970
I'd be interested in the 258
John 2blu442 would be interested in the 253
Old Jan 9, 2013 | 04:16 PM
98 man's Avatar
Here is some info from 442.com if that helps you
1970-
350 7040250
455 7040251
455 Toro 7040252
350 W-31 (6) 7040255
455 "442" MT 7040253
455 W-30 M.T. (6) 7040256
455 W-30 A.T. 7040258
455 W-33, 442 A.T. 7040257
Greg
Old Jan 9, 2013 | 04:55 PM
lemoldsnut's Avatar
What are you looking to get out of them? I might be interested also. Thanks Larry
Old Jan 9, 2013 | 07:20 PM
hadafew's Avatar
Thanks for the help fellows, I wish I still had whatever they came off of though!
I will try and figure a price and post them on the FS forum when I do. Again, thanks for the help.
Old Jan 10, 2013 | 11:01 AM
hadafew's Avatar
Can't reply to some folks, ........ PM box full.
Old Jan 10, 2013 | 11:12 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
whats w-33 i have a 7040257 supposed to be correct for 70 442 auto
1970-
350 7040250
455 7040251
455 Toro 7040252
Greg
Old Jan 10, 2013 | 12:14 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
"W-33 is a 1970 motor option only, optional on all Delta 88's. This was the 390hp 455 option (with dual exhaust), which was also the police package pursuit motor. Speedometer read "Police certified" on the bottom. Suspension and trim upgrades were separate options. Upgraded suspension consisted of heavy duty springs, boxed control arms, posi rear, rear sway bar, and special "OL" code TH-400 transmission". <this is a quote from 442 dot com FAQ>.
Old Jan 10, 2013 | 12:27 PM
GAOldsman's Avatar
"Car"mudgeon
7040253 = 1970, manual trans, 442, 455 engine (engine code TU)
7040258 = 1970, auto trans, 442, W30, with OAI, 455 engine. (engine code TT)
Old Jan 10, 2013 | 12:41 PM
7040257 is correct for a 70 442 with an automatic - I've seen 7040251 as well
Old Jan 10, 2013 | 01:34 PM
GAOldsman's Avatar
"Car"mudgeon
On an interesting note the W33 is Police Performance PKG on the big cars with 390 HP 455 dual exhaust and M41 (Three Speed Turbo Hydromatic Trans with Three Speed Torque Converter) and Y72 Heavy Duty Cooling & Alternator Option.
Bozang1
May 13, 2015 11:48 AM
Lady72nRob71
Jun 26, 2011 06:59 AM
starfire
Feb 26, 2011 11:51 AM
delta881972
Mar 4, 2010 05:14 AM
jeffs 89 cutlass salon
Drivetrain/Differentials
Oct 4, 2007 08:46 AM
