Rallye Pac question
Rallye Pac question
On my '69, I assume the area outlined in red in the picture are the gauge grounds. What is the one circled in yellow, and does it require some kind of isolator between the lock washer and printed circuit? I removed the unit and took it apart to polish the lense, and when I re-installed it, it blows the fuse when I turn the ignition switch on. Did I get something in the wrong place or omit something? I would appreciate some help, as I cannot find a good pic of this with enough detail to check it out.
If you can't get an answer here, call John at 731-571-0766. He is a great guy to deal with, and will have the correct answers for you.
http://www.redlineg.com/redlineg/Welcome.html
August 22nd, 2019 08:45 AM
