Rallye Pac question
Old April 4th, 2013, 05:59 PM
amesolds's Avatar
Rallye Pac question
On my '69, I assume the area outlined in red in the picture are the gauge grounds. What is the one circled in yellow, and does it require some kind of isolator between the lock washer and printed circuit? I removed the unit and took it apart to polish the lense, and when I re-installed it, it blows the fuse when I turn the ignition switch on. Did I get something in the wrong place or omit something? I would appreciate some help, as I cannot find a good pic of this with enough detail to check it out.
amesolds is offline
Old April 4th, 2013, 11:10 PM
Mr Shifty Sidney's Avatar
I just did a quick check on my 70-72 gauges and a 73 gauge pod. They are a little different, but there is not an isolater on these gauges.
Don W
Mr Shifty Sidney is online now
Old April 5th, 2013, 10:23 AM
Lance
ROCKET VAPOR's Avatar
If you can't get an answer here, call John at 731-571-0766. He is a great guy to deal with, and will have the correct answers for you.
http://www.redlineg.com/redlineg/Welcome.html
ROCKET VAPOR is offline
Old April 5th, 2013, 06:32 PM
amesolds's Avatar
Hey guys- Thank you so much for the info. I am going to ship the gauge pod to Redline to have them checked out.
amesolds is offline
Del70
April 22nd, 2021 12:21 PM
August 22nd, 2019 08:45 AM
Mocephus
July 8th, 2014 07:05 PM
danimal442
June 13th, 2011 09:42 AM
Allan R
October 6th, 2009 09:13 AM
Quick Reply: Rallye Pac question
