- 1970 442: Sports Coupe vs Holiday Coupe
- Against all odds... new 1970 442 pace car article
- '70 olds 442 under hood colors
- 66-67
- 1971 Ram Air hood stripes - help
- 50 miles a day on a 1987 442 in mint condition
- Dream Machines Event May 1
- Desperate in San Diego: Oil Pressure?
- 71' 442 cowl decode...holiday coupe vinyl top???
- Four-row radiator in '67?
- Cruise control in a '67 cutlass?
- Is this a real'67 442?
- Which repop air filter to use with OEM pie tin?
- 442 ram air hood
- Anyone done a stock fuel tank with sump?
- Bumper choices... help!~ 71 442 vert.
- Winter 2012 project - Need help
- Tires rubbing on SS brake lines. Help!
- help need vilyl top moldings
- 1968 442 rear bumper WIW
- Used OAI vs. Thronton
- 69/70 442 difference?
- 1967 442 4MV carb help
- Tracking history on a 69 442 matching # convertible
- 69 442 steering box
- 67 442 Head light bezel availability?
- rims
- Cooling
- 1970-72 442 Ram Air Style Fiberglass Hood with/hood locks
- 442 as a daily?
- 1969 Oldsmobile 442
- 1987 Oldsmobile Cutlass Supreme 442 Alsip IL
- My Mecum Car....
- Timing
- New Gold in California!
- 2 Questions: Tires & Stripes
- springs&shocks
- Wheels And Tires
- 1970 442 Convertible in Oregon
- dash
- Just got my seat belts back...
- Car Exchange magazine cover Yellow 442
- 68 442 rear bumper
- 1969 442 ragtop-anyone know it?
- 68 conv 442
- Junction Block / Relay Assembly Help
- need help
- Grille Bar ('67) Aftermarket (any difference?)
- Interior hood lock info needed
- Mondellos '70 442 Vista Cruiser
- can an 85 cutlass 200-4r shifter and shift cable fit in a 87' 442?
- '70 fan clutch to water pump hardware???
- Two different 404847 water pump styles???
- Transmission shifter cable replacement question
- emblem location
- Build sheet for '85-'87 442?
- Let's talk rear ends
- 14 X 6 SSII's any interest / worth ???
- Tachometer Recommendation?
- 1964 442 production plants
- Driveshaft stripes
- Need Members advice
- 1985 442 timing advanced way past tdc????
- Header install on a 67 442
- oai base
- Trash Talk:71' SX Conv't or 71' 442 Conv't
- is it a real W30?
- I'm mixed up, which is my original fan blade???
- Ac brackets for 67 Olds 442
- 69 W-30--Do you believe this?
- New Year
- Engine Build Question for 442
- 442 only colors?
- 69 442 ss1 rim
- Is this Lime Green right???
- Merry Christmas
- '70 442 "kf" water pump pulley identification???
- Can this even be done?
- W-27 rear axle
- washer bottle
- 1970 442 Vert Fan Shroud
- 72 442
- What's the Deal with W30's and Sound Deadner?
- 73 v code 442
- Ink stamped "74" on a '70 442 fan blade???
- 70 W30 Owners w/Original Motor....need some help!
- New Restoration Project...64 442
- 1966 Tri-Carb Oil Fill Tube & Fuel Bowl
- Correct water pump casting number???
- Another Oil Pressure Question (Part two)
- Happy Thanksgiving to All!!!!!
- Stripe or no That is the question
- Another 66 442
- Unusual shifter?
- Hood bumpers
- 1970 442 pic from 1974
- Where was Olds going Performance-Wise?
- help on a 69 442 convertible
- What are "F" heads going for today?
- Thinking about buying a 1972 442 Convertible
- Where is the second engine lift bracket?
- 1966 P/S pump rebuild now not working
- 66 442
- Can Someone Explain Fisher Body to Me?
- Engine Lift Bracket and Thermo Housing color on W30 Intake
- 1980 442
- 1966 Olds 442 Starter Removal?
- What does it take to
- Anyone know how to re-key a lock????
- To Undercoat or Not to Undercoat....that is the question
- DIY 1970 Mirror
- Wiper Washer Bottle Placement - 1970 442
- THrottle cable bushings
- 66 442 Tachometer
- 1969 442
- Broadcast sheet question
- 442 Gearing
- Fan hits on new shroud
- $64,000 Question
- Lug Wrench Codes
- Check this W30 out....and a question
- '87 442 for sale on C/L - Chicago Area
- Subject: Tires
- 70 442 w30's-Goodyear or Firestone tires?
- 455 in a '65 Sport Coupe??
- oil pressure
- 1972 442 w-30 trunk decals
- heater fan speed
- Thinking of buying a 1970 442
- Rare 442 at Fall Carlisle
- Rear End Gear? 342 or ?
- 70-72 Rear Spoiler (Wing) info needed
- GM Heritage Center? Anyone buy info from them?
- 70 OAI springs and tabs-correct or no??
- Phosphated hood latch photos
- OAI Air Cleaner Lettering
- Battery cables for 1970 442 W-30
- 442 trim question
- Heater Core Repair
- cancel cam
- Windshield molding
- Original 1970 W-30 Master Cylinder Help
- What Keys Do What?
- 1972 W-30 4-speed - What # is it out of 289 produced?
- Earliest 1970 W-30 build
- Ebay 1970 Olds 442 for sale
- Qustion about VIN
- 455 oil pan swap
- 1970 Steel OAI Hood Fact or Fantasy
- 69 442 post
- Barn Find Original Owner 70 W30 on eBay
- Dash
- Oai 1972 442 hood. How to tell real?
- 1971 442 holiday cope engine original paint color?
- 1970 Rear Glass Removal
- SS II lug nut torque
- 68 400 engine
- 70 442 Question
- Starter heat sheild
- Sway Bar wanted
- 1972 442 w-30 4-speed rare?
- 1972 442 floor mats
- 1968 442 fan shroud Where to buy?
- 1970-1972 W30 W25 442 info thread
- 442?
- 1969 442 wheel opening chrome on quarter
- need help with original rims size 442 1971
- 1970 Cruise control
- Another '66 442 cowl tag quiz
- 70 442 spoiler
- Radiator question
- GM Sportsalvage?
- how many are left, 66 - 442 conv. 4 speed
- Decal Placement
- W-30 w/ac
- mirrors
- Dustcover?
- Need a favor-68 442 Glove Box Latch
- new to forum
- '68 442 - What Belongs There?
- 1972 W-29 steel hood factory markings
- 1966 cutlass 442 convertibles bows
- Two questions for you smart guys.
- Any help with my tag?
- Any major downsides to buying 1967 Olds 442???
- Driving Factors?
- 1966, 442 convertible 4 speed
- 1966 Olds 442 Right Side (passenger side) Valve Cover Breather?
- 442 -69 Pictures!
- 1966 Olds 442 400 Cubic Inch Bocks
- 1966 442 Intake Valley Pan Installation
- antifreeze
- 72, 73, and 74 Olds 442 Question
- 8 track installation
- New top for 70 442 convertible
- Buying a car
- 1968 olds 442
- Correct block
- Interior upholstery kit quality
- 69 442 Drums
- tri-carbs
- Trunk paint
- Ralley pack with Nightwatch
- 14.58 MPG in my 71 W30 with 3.08 gears
- 1971 442 OAI Hood
- Cowl tag help
- Kanter Auto Products?
- Sealing Radiator (air flow)
- How many 1966 L-69 Tri-Carbs were sold?
- 1966 Olds 442 Vibration Damper
- new 68 69 442 bumpers?
- control arms and sway bars
- Posi tag
- 455 J Heads
- Inner fender refinishing
- 1971 442 Engine Question
- Questions on my 85' Cutlass 442
- '69 442 hood
- 69 442 A/C Bracket question
- Original '70 pdb master cylinder identification???
- Diff housing number and gearing
- 69 442 spark plugs
- Air Conditioning
- Kick panel speakers
- Grill & Bezel Paint
- Correct repro spare tire hook and retainer from inline tube!!!
- towing with Jetaway trans ?
- bypass hose used in other GM models ?
- '71 production
- 1986 442
- 87 442 mpg
- Intake Manifold, Air Cleaner 71 442
- washer jar location
- 70 W-30 4 speed, need advice
- 68 w30 #s
- Reproduction tic toc tach problems
- Thermactor hose connection
- 1967 442
- What do you guys think about this car (71 442 rag top)/picts
- 69 442 radio
- need 1971 442 info/ w-25 option info
- anyone here do a Auto to M/T swap?
- FE2 vs. F41 suspension package
- TH400 question
- 70 442 W30 stripes??
- 1970 original oil filler cap???
- T44 hood lock
- Another DIY OAI
- Coolant decal
