Two questions for you smart guys.
Old Aug 17, 2010 | 11:36 AM
cessna195's Avatar
I am in the process of rebuilding my 1966 Olds 442 and I have two questions.
1. My original Olds shop manual has a torque spec of 120 ft lbs for the mains. That seems too high to me. I am afraid I will break a main cap. I have seen mains brake around the bolt area of a bearing cap in days past when guys would torque a main bearing bolt.
2. I have instructions on how to install the rear main seal from the gasket set but it is not to clear. What would you guys do for installing a rear main seal?
This is the first Olds engine that I have ever built so I am asking for other guys experiences.
John
Old Aug 17, 2010 | 12:00 PM
1.My original Olds shop manual has a torque spec of 120 ft lbs for the mains. That seems too high to me. I am afraid I will break a main cap. I have seen mains brake around the bolt area of a bearing cap in days past when guys would torque a main bearing bolt.
The factory Chassis Service Manual was written by the guys who designed the car. Why would you want to use a different number?
2.I have instructions on how to install the rear main seal from the gasket set but it is not to clear. What would you guys do for installing a rear main seal?
We all throw away the rope seal and use a neoprene rear main seal from a Ford 460.
Old Aug 19, 2010 | 04:34 AM
cessna195's Avatar
Well I went out and bought a neoprene rear main seal from a Ford 460 for my engine. Are the any special instructions when installing the seal?
John
Old Aug 19, 2010 | 08:18 AM
John
Be sure you have the lip seal pointed in the correct direction when you install it. Offset the ends about 5 degrees from the parting surface of the cap for a little extra sealing, and dab a bit of RTV on the ends before installing the cap. I like to wipe a thin film of oil on the lip of the seal to prevent wear at startup.
citcapp
Sep 11, 2019 11:02 AM
jag1886
Mar 17, 2018 12:12 PM
mb197942
Feb 15, 2009 11:56 AM
catonine
Jan 18, 2009 02:46 PM
shaks 442 clone
Sep 24, 2008 01:38 PM
