Cooling
Old Mar 25, 2011 | 03:53 PM
patmills's Avatar
442forsure
Cooling
I have a '66 442 with a 425 Olds motor and tripower. It has no shroud and I want to be sure that the engine never overheats. I was going to install a shroud - I ordered one from Supercars but it does not fit the fan because the fan is a 19inch on the 425 motor and the shroud is for the stock 400 motor. But I am thinking that I would be better off installing twin electric fans controlled by a thermostat and an overriding manual switch.
I would appreciate any thoughts you have.
Pat
Old Apr 3, 2011 | 06:18 PM
oregontopcat's Avatar
Fans
Pat personally I would use an engine driven fan with a good fan clutch. No matter what electrics you use they will not move as many cfm as the engine driven fan. Just my thoughts, Dave
Old Apr 3, 2011 | 06:49 PM
patmills's Avatar
442forsure
Thanks Dave - I have decided to stay with a clutch fan. Also much less complicated!!!
Pat
68conv455
May 12, 2008 05:29 PM
projectheaven
Mar 15, 2008 10:21 AM
stevefree04
Jan 8, 2007 07:00 PM
ztim
Dec 22, 2006 12:44 PM
davy5
Nov 30, 2006 10:16 AM
