Correct block
Here's info on a 7B 442. second week of July build date./
Block 167 date code by distributor hole
Heads 139 Date code top surface of head just outside of valve cover lip
Distributor 6F Stamped # on distributor housing June 1966
Water pump 137 Date code cast on water pump
Intake manifold(Tri-Carb) 151 Date cast on intake by #3 runner
Exhaust manifolds 145 and 147 date cast on side of manifold
Engine unit # V120420T Stamped letter/numbers on the end of right side cylinder head.
All casting #'s are Julian.
166 or 168 would likely be original to your car.
Henry
Henry
