68 400 engine
Old Sep 12, 2010 | 08:10 AM
Stevec's Avatar
68 400 engine
I have a 68 400 engine with "C" cylinder heads. What are the really desireable cylinder heads for the 400 engine and is the type 'C' a good design and what is recomended to improve it. Thanks all!
Old Sep 12, 2010 | 10:41 AM
allyolds68's Avatar
Put the 400 G block in a corner covered in grease then take the C-Heads and all the 400 internals, buy a 455 block for $100, & re-build it. That's the best & cheapest way to improve it.
Old Sep 16, 2010 | 04:57 PM
cargo442's Avatar
what would you gain by doing that? just curious because i have a 1968 442 also. thanks.
Old Sep 16, 2010 | 05:54 PM
Sadly, the G-block 400 was apparently designed by the accountants. In earlier years, Olds used the same crank as the 425 in the 400 motor. This short stroke forged crank yielded a nearly square 400 motor (4.000" bore, 3.980" stroke) that was a very nice performance motor. Unfortunately when the 425 grew to the 455 in 1968, Olds again used the existing BBO crank with it's now 4.25" stroke to save money. To meet the GM-imposed 400 cu in limit on the A-body cars, the bore was reduced to 3.870". This long stroke, small bore motor has one of the worst bore/stroke ratios of any US-built motor. A 455 short block is definitely the easiest way to improve the situation, as Olds proved on the 68 H/O.
chrisneu68olds
Dec 30, 2011 10:17 AM
dgreen
Nov 6, 2011 09:40 AM
Gearhead442
Jan 27, 2011 03:03 AM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
