- Coolant decal
- Red lenses on door panels
- 442 sway bars
- oil temperature on 1966 442 ?
- 1972 442 hood
- '71 442 air cleaner lid decal
- 80's Reproduction parts for 442
- 68-69 bumper jack 442 f-85
- W-25 Hood Needed.....
- Canada built 1969 442 W-30
- Gas Mileage??
- '85 442 grille
- A good day today
- What do you guys think about this 442?
- Need Help Identifying a part
- Spark plugs for 1985 442
- 1987 442
- Daily drivers
- 71 442 Stripe Kit
- Correct radiator cap for '70 442
- 1986 442 in Sweden
- Look at the 442 on this website
- 1969 442: OAI w/Air Conditioning?
- Radiator hoses with correct gm ink stamped markings???
- Some pics of original 66 442 Tailpipes
- W-25 Hose Question...
- W-30 Find
- 66 tri power oil filler
- Rally pack Bezel
- 442 front end droop
- Voltage regulation and grounding
- lower dash and steering column paint
- Could you help me?
- Howdy - should I get it?
- how is that seal called in english ?
- For those that use a TomTom GPS...
- radiator.
- Correct Codes
- 66 442 trunk trim resto
- Is my harrison radiator the correct code for '70 442
- trim rings
- 1969 sport coupe
- '70 442 bypass hose correct clamps???
- w-30 intake
- Looking for Junkyard In or Near Texas
- head Number?
- My 1970 W-30 convt 4 speed restoration
- need help 1987 442 maroon seats and door
- 1966 442 Breather Right Valve Cover.
- opinion needed for CHRIS83 on 74 Cutlass 442
- WTB 70-71 442 4 speed
- 1970 W-30's When did production begin?
- 67 throttle cable install
- W30 Carburetor
- Anyone running BFG drag radials 325/50/R15?
- Pertronix Ignitor II
- Original Owner Picture...too cool!
- Pertronix Ignitor II Question
- 1970 442 Question?
- 68 442 throttle cable to carb help
- improve steering "accuracy"
- 67 Rally Pac
- '70 Vert, tires and wheels.....
- 1969 w30 oai
- Scoop Covers??
- Q's 70 442 badging and paint scheme
- '73-'77 442 How can I tell?
- A question about "southern cars"
- My 71 442 tach is way too fast
- Anybody near Indy?
- 1969 442 factory floormats
- Stripes painted or not?
- Swapping wheels - will they fit?
- 442 sport coupe or holiday coupe?
- 68 442 data tag question
- 69 442 Post tan interior resto question
- 1969 442 Build Sheet
- SSI wheels in 1968? Or not?
- First time owner and new member
- windshield butyl thickness 69 442
- shifter bushings
- Proper Spare Look
- build sheets
- hey folks! 1966 L-69 question....
- new member, new owner
- Back on the Road Again!!!!
- 1972 Fasten Seat Belt Dash Measurements
- 1969 Cutlass S and 1969 442 Differences
- Missing part number ?
- is it a sin (66, 442) ?
- "Muscle Car" on Spike TV Sat 12/19 "442 profile"
- Has anyone installed a PCV into an aluminum intake manifold?
- Rocker panel number found
- 1987 442 parts wanted, please help
- here's 1 for you 69 'ers
- W-30 1970 Number vin #
- why is this engine commented as [VERY RARE] ?
- A question for 1968 Guru's
- Floor pans
- Convertible Top Motor
- 442 on-dash tachometer wiring ?
- 71 455 Intake manifold fitting/O.A.I
- A question, a request and one hell of a long story.
- did you raise your olds???
- interior: '71 442
- Plastic Window Rollers - Available or Not?
- Looking for advice on 455 engine paint color
- Am radio conversion
- Fuel Pump question
- 1965 A-Body Rear Seat Belts
- Squeaky Center Cap on Sport Wheel
- Manual to power steering converion
- Help 69 442 buds ?
- 442 (?) on ebay??? check it out -
- Wittek tower hose clamps
- 71 air condition
- Retainer loops for wiper fluid hose?
- W-35 On A Convert....
- 1969 a/c
- 1966 442 mirror
- Need Help with this Jack
- Correct Battery - 72 442?
- 71 glove box lamp
- Carberator losing prime
- Hood hinges/springs question
- Demolition Man - 1970 Olds 442 red w/ black stripes
- Covertible top
- Highway RPM's
- W-30 TOP END....
- 1971 Olds 442 tribute car - trim question:
- 68 power antenna location
- 442 1970 PARTS NEED!!!
- Console to Dash harness
- is my olds a fake
- 71 Ignition switch
- receiver dryer replacement question
- Top Trim
- Power/Non Power Brakes
- Look at these pics tell me is this a rust bucket ??
- MECUM '70 4-SPEED CONV...
- GM part numbers ?
- 75 olds 442 help decoding
- 1968 442 W-30 'vert
- Sheilded wire from tach
- 71 Convertible repro pillar post pads
- # OF STARTER AND COIL 442 1970
- Need 7040253
- 71 radio capacitor
- acclerator cable/other woes :(
- Where to connect my HEI on my 68 442.
- walrtips 442
- 442 CARB ID
- Need some help with 68 442 parts/info..
- Original spark plugs?
- Overhaulin episode on Discovery channel - 68 442
- 72 Olds 442 OAI set up
- tick tock tach question
- New to Forum - my 72 442
- 69 442 engine color
- Sharing our 1970 442 Vert.
- SS1 Chrome?
- 350's in 442's
- Quadrajet carb adjustment question
- REAL nice '70 W-30 442 at MCACN
- Open faced alternators
- Windsheild wipers are alive!!!!!
- 1968 442 build sheet question
- 70 Harrison Radiator
- Heater hose routing/look
- Newbie from NE Alabama
- 1970 W30 Qjet
- Right color paint for block
- '69 442 on eBay
- Trunk splatter paint
- new 68 442 convertible?
- Cowl Tag De-coding 66 442
- 442 with a manual tranny
- What size tire are you using???
- '68 'vert on eBay for $5500
- rear shocks
- Options listing for 1970 442
- Think it's worth it? $3900 CAD
- Vinyl top material
- Back from the track
- 2nd opinion wanted on my carb issue
- Help!! on this 442
- Trading for a 442
- 1969 442 chrome trim
- Intake Gasket debate
- weasel's getting all the attention...
- Car Show today
- "nutter new member with a 442!
- 1972 W29 cutlass
- Please help with rims
- Difference in value - SB vs BB
- Mufflers for 67 442
- looking for 69 w30 info
- Clutch assembly pics request
- Why don't we see this?
- 67 442
- 442 clone new Shoes
- pictures of my 1966 442
- tire size/rear end formula ?
- what is stock exhaust size on 67 442?
- Help on a speedo issue
- 68 442 PROTECT-O-PLATE
- 1968 Mod Rod 442
- how much to restore a 68 442 convertible?
- Help Decoding 65 Trim Tag
- 1969 442 Newbie pictures
- Did I just get ripped off? (ball joint)
- MPG estimate
- 1969 442 Newbie
- Junk yard mistake
- Wisconsin 1969 442
- 1970 to 1969 dash swap
- 1972 Cutlass core support bushings
- Ram Air Hood
- 1970 442 convertible stripes
- Newbie Hello
- Alternate location for Tach ??
- Newest member of the family
- help--1968-69 duct work
- Greenhorn with a fresh find
- Water temp gauge on '72 442
- 1968 Oldsmobile Cutlass with Dealer Added W-30 Package
- 1972 442 Convert.
- Got my new 442
- newbie with 68 442
- 66 Dash Mounted Tach
- 1966 442 value
- new shoes on the 65
- AC on w-30
- Want to know if i have a 442
- Motor in a '70 442
- 1986 442 vin 1G3GK 4791G P3985 49 TITLE
- replacing seat covers?
- OAI
- Newbie with a Weird Hood question!
- New to site
- just found this site
- Dealer installed 455
- Hello all, new and need some info
- Correct Secondary Rod Hanger
- Five blade fan??
- Back with good news!?
- 1970 trim tag paint code
- '70-'72 side stripes (not W-30)
