1969 a/c
Old Nov 9, 2009 | 06:06 PM
IDAS 69's Avatar
1969 a/c
THIS LOOK AS ORIGINAL?
Old Nov 9, 2009 | 07:55 PM
rcorrigan5's Avatar
Randy C.
What you have there looks like the real deal, but there's a couple more items to check on your compressor. On the upper right side of the red part of the tag, the numbers 869 in black should appear. The model number should be 5910698. On the "Oldsmobile" line, it should say 4.00 LBS. And finally, the code number is the actual manufacture date of your compressor. The first two numbers are the month (01=JAN,..., 12=DEC). The second two numbers are the day of the month. The fifth number is the year (should be an 8 or a 9 for a '69 model car), and the last number is the shift at the plant that manufactured the compressor. The date on your compressor could be anywhere from around 2 weeks to 3-4 months before the assembly date of your car (mine is a couple of weeks). That's all the news you probably didn't want to know! The installation looks just like my '69, and my '69 hasn't been altered - it's what came from the factory. My air cleaner snout is a bit more aft than yours, but that just might be the way I put it on.
Old Nov 30, 2009 | 06:15 PM
IDAS 69's Avatar
Thanks RC.......
I'm pretty sure I have a complete original...birthed with...ha. Thanks for your input.I've printed It out to also verify mine as an "Original"
crystal59
Dec 13, 2024 06:38 PM
Gearhead442
Feb 2, 2020 11:56 AM
mcutlass1969
Drivetrain/Differentials
Feb 12, 2008 08:59 AM
