SS1 Chrome?
Old September 18th, 2009, 06:06 AM
69'442's Avatar
SS1 Chrome?
I am restoring a set of 1970 ( I think) SS1's. Are the five spokes chrome or polished steel. They are not as shiny as the chrome on a bumper. I was told by a guy I should polish them out with red scotch brite. I don't want to ruin them. What have you guys used on this to make them look better? Are these 70. They have D 14X7 -JJ 878 M4 on the side and M4 4 23 LZ by the valve hole. Thanks
69'442 is offline
Old September 18th, 2009, 06:24 AM
Trying to remember member
wmachine's Avatar
They are chrome, but are bead-blasted (or such) because the areas in between the spokes are painted black. Back in '66 when they started making SSIs, they found the black paint wasn't sticking to the chrome centers. So they started to blast the centers to dull the chrome a bit to get the paint to stick.
Sounds like you got some bad advice.
wmachine is offline
Old September 18th, 2009, 08:34 AM
69'442's Avatar
Thanks Kurt, I figured that scotch brite wouldn't be good. I will just polish them up the best I can.
Bob
69'442 is offline
Old September 18th, 2009, 02:05 PM
442Harv's Avatar
On chrome I use fine steel wool and polish.
442Harv is offline
Old September 18th, 2009, 03:31 PM
My442's Avatar
I believe the chrome on SS1 wheels is a process called flash chrome, which has a less shiny finish.
Use autosol and very fine steel wool to clean the spokes.
My442 is offline
Old September 18th, 2009, 07:24 PM
stlbluesbrother's Avatar
I just refurbished a 1970 SSI wheel today - B 14x7 JJ 878. Last week I refurbished 4 with the stamp C 14x7 JJ 878. It was quite a undertaking, but I have the process down pretty good.
Anyway, I used Wadding Polish (by Eagle One) to clean the chrome. Then, for good measure I applied Chrome Polish (paste) also by Eagle One. The chrome shined up nicely for being 39 years old.
stlbluesbrother is offline
Old September 19th, 2009, 08:23 AM
wmachine's Avatar
Very well could be. I know when they first started the (call it) "satin" finish in '66, they took the existing regular chome finish and media blasted them to dull the finish to get the finish to stick. It is entirely possible that the process to finish the centers changed over the years.
I have a number of SSI wheels over the years thru '69 to compare (including some early '66 wheels that have bright chrome centers), but I don't have any '70s (or '71s) to look at.
wmachine is offline
mat1227
May 25th, 2014 11:43 AM
Sgt17
January 26th, 2014 07:53 AM
Eggman
November 7th, 2013 05:26 AM
bensdad67-442
April 15th, 2012 04:00 AM
hurst68olds
June 3rd, 2011 09:40 PM
Quick Reply: SS1 Chrome?
