What size tire are you using???
Old Aug 15, 2009 | 07:03 PM
ctrain22's Avatar
I have 15x7 rallies that I got for my 68 442 and I'm trying to find the right size tire. Looking at 225-70-15 or 225-60-15. What size are you all using. Pictures would be great.
Old Aug 16, 2009 | 07:31 AM
jeffu231's Avatar
I have 245/60R15 on mine. That size and profile is very close to the original 14 inch diameter and keeps the speedometer close.
Old Aug 17, 2009 | 06:22 PM
oldsdroptop's Avatar
here's my babies new shoes....
I'm running 245 60's BFG on mine....15" of course. And wheel vintiques chrome SS1's............... gotta keep it real. Olsdroptop
Old Aug 17, 2009 | 06:34 PM
666 the legend's Avatar
...275/60 r 15...
Old Aug 17, 2009 | 08:23 PM
derek nesdoly's Avatar
olds..older..oldest
Originally Posted by 666 the legend
...275/60 r 15...
Using this size on my ride.Had to go for 1972 Olds 98 rear coils to stop the "rub" of the rear tires on the fenders!! Then re-did the front coils to level her out.There are some pics of my car on the "OCC" thread [red on red 69 442] ........Derek
Old Aug 31, 2009 | 09:30 AM
BerBer5985's Avatar
Yeah I was wondering that size tire would rub.
Old Aug 31, 2009 | 02:18 PM
4fortwo's Avatar
You have to account for the wheels backspace. I use 275/60/15 and have plenty of room but the wheel has a 4.25" backspace on a 15x8. If you run that tire on anything less than a 3.5" backer you'll have trouble.
Old Aug 31, 2009 | 05:04 PM
ziff396's Avatar
I am running BFG 245/60/15 on the front and BFG 275/60/15 on the rear. 7" front SS1 wheel vintique's and 8" on the rear. 1" lowering springs on the front and stock rear springs. Sits nice and no air shocks! 72 Cutlass 455. Pic's soon.
Old Aug 31, 2009 | 06:20 PM
marzgtp1's Avatar
Olds-Can
I'm running 255/60/15 cooper tires I just for 65.50 each plus shipping.
Old Sep 1, 2009 | 03:03 AM
Yellowstatue's Avatar
Cool Tires
I am using 255/60X15 on the rear of our two '68 442's and have no clearance problems using used Vista springs to get the *** end up...
Old Sep 9, 2009 | 09:16 PM
stlbluesbrother's Avatar
I wonder if I'm going too small on my 1970 Cutlass? I just ordered BF Goodrich P225/70R14 to go on the original 14x7 Rally SSI's. This tire size was determined from a Tire Conversion Chart based on the old G70x14 (white letter) standard. http://www.tirerack.com/tires/tirete...sionchart.html. Any thoughts?
Old Sep 9, 2009 | 09:35 PM
svnt442's Avatar
Those are the correct diameter for the car. What engine do you have? Anything with power will over power them in a hurry.
Old Sep 9, 2009 | 10:08 PM
Hi Randy,
The Cutlass Supreme has a 350 v8 with 4 barrel carb. And the differential is geared as highway cruiser at 2.56
Old Sep 9, 2009 | 10:32 PM
442much's Avatar
I'm running the original size for my car...225/70Rx15 or GR70x15
Old Sep 9, 2009 | 11:26 PM
svnt442's Avatar
Originally Posted by stlbluesbrother
Hi Randy,
You should be OK and have the ability for a little tire smoke if called for .
I had a 2.56 geared 70 run in the high 13's (13.89 @ 97mph) with a mild 455. The car was capable of 150 miles per hour I'm sure, but the suspension left A LOT to be desired so I never attempted it.
Old Sep 10, 2009 | 05:53 AM
This is a good thread. It is good to know what tire size others run so you can have a starting point when buying new wheels or tires for your own car. Now if only I could figure out if I could run 10" wheels on my 98 behind the rear fender skirts.
Old Sep 10, 2009 | 11:19 AM
svnt442's Avatar
Well if you cut out part of the trunk............
Old Sep 10, 2009 | 11:29 AM
Old Dec 15, 2009 | 04:38 AM
Bob Lynch's Avatar
tire smoke
all these threads talk to stock like tires for normal street use ... my motor is hot street, occassional strip ... a little throttle and the rears just light up ... they are BFG T/As, 245s on 15s ... need more footprint and stickey compound to help with hookup ... do not want to smash any metal with a sledge hammer ... can someone add color? Bob Lynch
mmcilroy
Sep 7, 2010 05:02 PM
ctrain22
Aug 20, 2009 04:47 AM
Rdrokit
Jul 5, 2009 05:11 PM
ctrain22
May 13, 2009 12:55 PM
