Hood hinges/springs question
Old Nov 1, 2009 | 06:16 AM
442's Avatar
70' W-30 Convertible
Hi,
Does anyone know if the hood hinges and/or springs for 1970 OAI fiberglass hood are different than a standard metal hood? I suspect same hinges but maybe different springs but not sure.
Thanks,
Richard.
Old Nov 1, 2009 | 06:22 AM
While we're on the subject. Any diff between 69 H/O and 69 442?
Old Nov 1, 2009 | 02:48 PM
My442's Avatar
No differences.
Same hinge and spring.
Old Nov 1, 2009 | 06:06 PM
442's Avatar
Thanks,
Richard.
Old Nov 2, 2009 | 06:50 AM
4-ever-olds's Avatar
Originally Posted by My442
No differences.
Which ones are the same? The ones for the 69 H/O and 442 or the ones for the 70 w-25 and regular steel hoods? I thought there were different springs in the OAI hood hinges but I dunno for sure.
Old Nov 2, 2009 | 07:06 AM
Wasted's Avatar
I think that if you have a OAI hood with a steel frame then its the same springs. If you have a aftermarket hood that has a fiberglass frame then you need the lightweight springs.
Old Nov 2, 2009 | 10:03 AM
junior supercar's Avatar
for factory hoods:
70 OAI hood uses same hinges and springs as all the other 70s with non OAI hoods.
69 also used the same hinges and springs regardless of hood
aftermarket is a nuther animal, altogether
Old Nov 6, 2009 | 05:39 AM
jims2000lt's Avatar
11.52 @116
Finally got my new hood hinges (69 442) from The Generals Store in Lansing, IL. They are repreoductions and made overseas. The quality is spot on to my worn out originals. I picked them up on Tuesday and ordered them August 31.
Just thought I would share.
Old Nov 6, 2009 | 06:14 PM
442much's Avatar
When I got my OAI hood I was told that I'd need springs for the fibreglass hood. I didn't change them but I am careful when closing it. I push the hood toward the windshield to "break" the hold. When I open it, it can get away from you if you're not careful. I think they make springs for the fibreglass hood. Whether you need them or not is your call. I wouldn't change out the hinges, no difference that I can see.
RetroRanger
Oct 9, 2014 04:18 PM
W31driver
Mar 26, 2014 05:41 PM
halfmoontrail
Body work
Apr 3, 2013 04:59 PM
georgiaboy697
Jul 2, 2010 09:23 PM
