View Full Version : 442
Pages :
4]
- 64 442 tahitian yellow vert on Ebay with auto trans, ALERT ALERT
- Engine brackets
- 1970 - Body Tag Question
- 1978 442
- 67 442 Convertible Advice
- Is this 68 442 worth the trouble?
- Broadcast Card Questions - '70 W30
- 1972 442 v code convertible
- Fuel Fill Issues
- 442 holiday special
- New Member - 1969 W30
- 1987 cutlass 442
- Looking for Purchase Advice
- W30 Ralley Cluster
- 72 442 Help Needed
- Update on 64 F-85 442 Project
- 1987 Olds 442
- 1969 442
- Ants in my rear end....this is a first
- Gas tank sender wire (brown) how does it route? '68 442
- 70 442 rear bumper
- Hi All info on 1970 W30 Production numbers needed.
- 69' documentation???
- Holley Sniper EFI
- 1968 442 Stripe Example - As Rerference
- '72 Cutlass
- Shock color
- 1966 Cutlass 442?
- 65 442 body tag
- 1964 Rear Differential determination
- 1999 Olds Intrigue 442
- 1964 - Differences between an F85, 4 Barrel, 4 Speed, Dual exhaust car and a 442?
- Like or Dislike?
- Asusport's 1964 442 Pics posted
- 1964 F-85 Club Coupe and 442 questions
- Mismatched air filter
- 99K Holy Grail
- New Member just bought 1964 442
- 1970 442 orig engine unrestored
- need help..1964 442
- c heads over d heads
- 72 olds 442 inteior problems need help
- pictures of nassau blue and tahitian turquoise
- Looking for my fathers old '68.
- Original engine check?
- Things to look for in a 65 442
- 1969 w-30 next project
- 1970 442 Broadcast sheet
- Curious, was there a '73 442 ?
- 67 W30 Air Filter dimensions
- W30, Track Pack Air Cleaner Info
- Opinions on this stamping?
- ? about spare wheel/tire in 72 W30
- Just bought a 1969 442 on ebay
- 70 442 W30 (clone?) value?
- Berejik 1977 442
- 1987 442 - Blue
- 1967 442 from far away
- 1969 w-30 sport coupe production numbers
- The new Oldsmobile 72 442 W30
- 68 442 vert 400g pulleys and water pump question
- A couple of questions about an '85
- moving forward
- 1970 )lds Cutlass Pace Car on EBAY
- 14,000 mile 455 4 Speed 71 442
- 1970 W30 Inner Fenders - Red or Pink
- Correct Hood '71 442
- freshly sprayed 1970 442 numbers matching holiday coupe
- '68 Dual Gate Over/Under Carpet?
- Found 1967 442 - Paint Question
- Two of a kind
- 1966/67 Stick pedals and bellcrank?? Not sure??
- Cutlasses and a 442 for sale at private auction in Okla
- Coil Spring Replacement
- Some not so new tunes for the 442
- Hei Distributor
- HEI conversion
- Need to upgrade exhaust system 70 442. Looking for advice
- 1968 442 Mod Rod
- brake booster disconnect ?
- Going out on a limb
- 1967 w30 442- thoughts and oppinions
- header choices
- What Spark Plugs are you using
- Vacuum Diaphragm location
- Help ID rear gears
- Sourcing a front bumper
- Q & A session on this car with Jensenracing77 - 70 W-30
- heads for 455
- 1971 442 rotting away in plain sight. Sad, just sad....
- 69 442 Options
- carb problem?
- 69 442 rear axle decode
- What rear end differential do I have in my 1968 442?
- 1968 W-30 stripe delete
- 1970 pace car w30?
- Air conditioner
- Ran Across this 442 in Peoria
- Convertible top cylinders
- Which Air Cleaner
- New 4 core radiator
- 442 wheels
- Documented ?
- Fender emblem hole placemen
- 1967 442 W-30 (?) on FeeBay
- 1972, 442 with 455 ram air
- 68 front suspension finishes
- Found one after 40 years
- Hood stripes
- Carburetor recommendations
- 69 numbers matching 442
- Need help identifying these part
- HMM Buyers Guide for 1969 442
- 65 442 engine frame mount ?
- 1968 442 vin/cowl decode
- 70 442 grill size
- 442 Found In woods. Worth Restoring???
- 64-65 Cutlass back seat dimension
- Looking for original drivetrain
- 85 442 that's made its way to the Midwest
- Hello everyone, 442 question
- 442 rad over flow can?
- New to me 1973 442
- Can anyone verify 442?
- 1968 olds 442 engine vacuum diagram
- performance intake help 69 442
- !972 442 Cutlass Identification
- What is this card called?
- Emblem replacement
- 85 442 info needed
- 1969 Olds 442
- 1980 Olds 442
- Cowl Tag decoding needed
- Tic-Toc Tach Knob Removal
- 1967 442 Supreme Holiday Coupe
- 71 W30 broadcast card help?
- 1970 442 Restoration
- 69 442 top molding
- p/s ruturn hose
- Used Crankshaft 1972 455 4 speed value
- Desirability
- 69 442 trunk lid template
- 68 442, looking to buy, whats it worth?
- Question about 1964 442 frame
- 14 x 6 R coded rim Manufactures?
- What happened here? Verified 70 W30 in seemingly good shape only $40k?
- Aftermarket throttle body fuel injection
- W-30 scoop ducts
- Replacing Manual Window Regulator
- W30 Verified!!! Still attached to rear seat.
- Finally... PA to NC - 70 442 W30
- '68 Ram Rod questions
- '69 Holiday Coupe 442 Clock
- 67 442 rally pac gauges
- 1972 Radiant Green 442 question
- 69' 442 mufflers
- 442 info
- 1968 w-30 wheel covers
- 1969 Floor shift boot and retainining ring.
- Can't seem to ID a code on a build sheet
- Check out these stripes
- buying 442... I think...
- Dallas Car Sharks
- Exhaust steam
- 69 442 Steering Wheel
- 68 442 wheels
- Have never seen a 442 like this..
- Stock Redline on a '66 442
- decode cowl plate
- 1966 Sindwinder Tach not reading right
- '68 4-4-2 Trunk Weather Stripping
- Clock module removal
- Dash 86 442
- 72 442 w30 starter
- Rear Gears
- Trunk layout
- Need help Decoding Cowl Plate
- 4 speed console
- what are you guys putting in your 455s
- 69' 442 Fuel Pump
- Need help finding clues on a 1970 4-4-2
- plain cars
- Is it a true 442
- '70 rear speaker correct part number
- before I go for it :) any tricks on installing....
- Looking for 66 Olds 442 die cast car....
- Trying to Verify '72 442 W30
- Where in the world
- Am I Missing Something???
- Rotor dust caps
- just bought my frist cutty
- Engine paint for '68 442
- 68' 442 Window Regulator Rollers
- 67 Cutlass-442 fan shroud
- Really stupid mistake
- Howdy - 1968 4-4-2 LOTS of questions
- 1970 442 W30 Valve Covers vs non-W30
- My Father in law was an Olds maniac - Pics inside
- Real 442 or not
- Thinking of selling my '72 442 Convertible
- Struggling on first gear. Why?
- Ram Air hood
- Shifter swap??
- Help identify what was here before
- 72 442
- 1965 442 3spd in the floor
- Replacing kickpanels...any gotchas?
- Value Question
- 1967 442 ID question
- anyone know this car possible 71w30
- 1968 442 convertable multiple question
- Trifecta of W-30s
- Need advice on this 442
- Kickpanel with AC?
- So hot in my 68 442 - cooling advice?
- Barn find, weird headlights
- engine size
- identifying an 86 442
- Safety first in a 442
- Today was a milestone
- 70 W30 transmission
- 67 '442' antenna
- 65 442 With Corvette Rally Wheels?
- 1968 442 trunk mat "help"
- Verifying authenticity of a 1970 442 W30 H/O
- door handle relay
- Transmission tag
- GM Mark Of Excellence Decal in '70?
- Heads
- Fender wells
- 1969 442 w/455 W34 HO
- fuel line replacement 68 442
- Speculation
- Leaking oil pan
- 1972 "442" Spotted ?
- TH400 shift kit?
- 3rd gear transmission slip
- Q jet question
- 70 w30 oem hood value these days?
- Track Pak
- Air shock bumper sticker
- Need some help
- 1968 w-30 trunk decal
- 68' 442 Replacing Drivers Door Power Window Motor
- 1972 442 with bench and column shift
- Gas Tank vents on '68 442 ?
- W-30 Identification
- 67 442
- Pre-inspection
- 67 442 350 engine install
