Leaking oil pan
Old May 13, 2015 | 11:58 AM
442craig's Avatar
Leaking oil pan
So I have a oil leak in the back of my '68 442 400. The engine is brand new. How difficult is it to remove the pan? Will it slide out or do I need to lift the engine? Also what type of gasket should I use.
Thanks in advance
Craig
Old May 13, 2015 | 12:08 PM
It's a pita to do it with the engine in the car. I would get under there and check the pan bolts and snug them down a little bit all the way around the pan. Also double check the valve covers for leaks.
Old May 13, 2015 | 12:12 PM
442craig's Avatar
Yep, I have done all that, this is where I'm at. Not the news I was looking for!
Craig
Redog
Oct 20, 2015 03:29 PM
defiant1
Aug 12, 2014 04:43 PM
defiant1
Aug 26, 2011 09:45 AM
Dan Wirth
Oct 18, 2009 07:27 PM
