1969 442
Old March 30th, 2017, 02:48 PM
jerrybetty5's Avatar
1969 442
I am trying to find the correct windshield spray nozzle. Also how it installs. Tried the internet but got mixed info on part. A photo of them installed would be great.
jerrybetty5 is offline
Old March 30th, 2017, 05:37 PM
Yellowstatue's Avatar
Two of 400681 nozzle fits '68-'72 W/recessed park. Held on with one (each) small hex screw. Look at hole under hood for diameter (pretty small).
Yellowstatue is offline
Old March 31st, 2017, 09:49 AM
acavagnaro's Avatar
Look in the usual places for reproduction pieces (Fusick, In-Line Tube, etc.). I don't know PN's but they're readily available. You'll need 2. As mentioned, they each mount with a small screw to the underside of the hood in front of the wipers. The new nozzles will likely come with the screws.
acavagnaro is offline
Old March 31st, 2017, 12:24 PM
Randy C.
rcorrigan5's Avatar
Attached is the page out of the '69 assembly manual that shows where the nozzles go and how the rubber tubing is routed. The nozzles and tubing are available through Fusick (www.Fusick.com). The nozzles are part number WN6881, the rubber retainer on the hood is part number WWH682, and hosing is available under part numbers 4660 (correct size hose with white stripe as original) or 4457. I believe Fusick uses newer part numbers now but those numbers should give you a start. You can call them directly at 860-623-1583/1589. They are good and will know what you are talking about!
Randy C.
'68 4-4-2 convertible
'69 4-4-2 convertible
rcorrigan5 is offline
crystal59
July 6th, 2023 04:39 PM
Gearhead442
February 2nd, 2020 11:56 AM
halfmoontrail
August 31st, 2013 09:05 PM
62radarlove
January 19th, 2012 09:05 PM
mcutlass1969
Drivetrain/Differentials
February 12th, 2008 08:59 AM
Quick Reply: 1969 442
