performance intake help 69 442
Old Feb 28, 2016 | 02:38 PM
rocket4421's Avatar
guys i need info from you all im looking into changing from the stock intake to one with a little more power im going with msd distributor has anyone changed theirs and had good luck or bad? i have a 400 6.6 v8 any help would greatly be appreciated thanks guys
Old Feb 28, 2016 | 02:53 PM
Your manifold choice needs to be based on the components of your engine/drivetrain for it to work together. There is no real performance improvement just by changing distributors.
Old Feb 28, 2016 | 03:08 PM
rocket4421's Avatar
Info
So it is a 4 spd engine rebuilt with the slightest bit of a cam 10 over i believe also headers with 2 1/2 inch exhaust i can post more info if needed.thanks for the help.
Old Feb 28, 2016 | 04:18 PM
What rear end gears? How will you use the car? What carb?
A Performer is the better choice for a street-driven car. A Torker is probably better for the drag strip.
Old Feb 28, 2016 | 04:54 PM
rocket4421's Avatar
Alright rear end gear 3.91. The carb im putting on is a demon. 725 road.. Weekend driver .maybe a road trip or two . guys thanks for the info.
Old Feb 28, 2016 | 08:04 PM
83hurstguy's Avatar
The edelbrock performer is probably your best bet.
Old Feb 28, 2016 | 08:25 PM
Octania's Avatar
Stock Toronado intake, 68-72 issue
Bernhard
Feb 5, 2013 10:31 AM
svnt442
Jul 17, 2011 04:43 PM
Rocket_52
Jan 31, 2011 10:18 AM
eddieunderground
Jun 26, 2010 06:29 PM
wmachine
Dec 30, 2009 05:55 AM
