Aftermarket performance intake manifold
I don't know of any single carb aftermarket manifolds but occasionally you will find a multi carb setup on ebay. The stock manifold isn't bad, although the stock 4-jet is small and its throttle bores in the manifold are smaller than many aftermarket carbs use. You can grind or bore them out as needed. a camshaft change will most likely help more than a manifold would anyway.
wmachine
December 30th, 2009 05:55 AM
GoodOldsGuyDougie
April 15th, 2009 05:02 PM
