carb problem?
Old Jul 24, 2016 | 08:09 AM
ben442's Avatar
carb problem?
Quadrajet No 70241253
Looking down the carb I don't see any gas being shot when I actuate the throttle after it sits for a day or two.
After about a 10 second crank the car fires up.
Fuel bowls empty?
Rebuild time?
Thanks Ben
Old Jul 24, 2016 | 05:27 PM
ronzz572's Avatar
Yes the fuel wells are leaking internal and drain the carb after sitting. There is a spongy gasket in rebuild kits that seals these. It goes between the throtle plate front and center section to seal it. Some people use epoxy to seal them also.
Old Jul 24, 2016 | 05:31 PM
ben442's Avatar
Where is the best place to source a rebuild kit for this carb? I'm located in Ontario?
Old Jul 24, 2016 | 05:40 PM
I buy them at NAPA.
There are other reasons for the fuel bowl being low/dry after several days. According to Joe P the leaky well plugs was an issue with the early (60s) QJets and not so much with the later ones.
D Appeldorn
Jun 14, 2008 11:47 PM
Pghstarsky
Apr 4, 2008 07:19 PM
1987supreme305
Jun 6, 2007 01:41 PM
Gee
Jan 27, 2005 04:57 AM
Gee
Cars Wanted
Jan 26, 2005 12:02 PM
