Opinions on this stamping?
Old Dec 10, 2016 | 08:47 AM
PUREW30's Avatar
Opinions on this engine pad stamping? I have mine. Seller is representing as a matching number block.
Old Dec 10, 2016 | 10:52 AM
I'm sure it's a "numbers matching" block - NOW. It just isn't the original block (nor the original stamp).
That isn't even close to the factory font or impression. And the factory did not stamp the number on two lines.
Compare to these known factory stamps.
As compared to this:
Old Dec 10, 2016 | 11:04 AM
oldsmobiledave's Avatar
VIN stamp
Perhaps a service department re-stamp on a warranty block but zero chance of that being a factory VIN stamp.
Old Dec 10, 2016 | 11:38 AM
PUREW30's Avatar
Agreed. Never seen a factory stamp look like that. I've seen two lines on SR blocks but obviously no vin number on an SR block. Depth, spacing, two lines, and font are all wrong. This is from a '71 Bittersweet W30 on ebay right now.
Old Dec 10, 2016 | 12:56 PM
Also note the relative angles of the characters - I believe that the original stamp was made from a single holder that was loaded with the correct number, then stamped on the block, transmission, and perhaps a few other places, depending on year - the original characters may have had slight misalignment top-to-bottom, but rotationally they were all straight.
These characters were individually stamped, and each is on a slightly different axis.
It doesn't even look like the "re-stamper" tried.
Old Dec 10, 2016 | 01:04 PM
I agree with Dave that this is likely a dealer replacement. The dealership was SUPPOSED to transfer the original VIN derivative to the new block when a replacement was installed. This often did not happen, and there was no direction (nor likely the ability) to replicate the factory font or format. Only the transfer of the characters mattered for legal purposes. Frankly, having the restamped VIN derivative be so different from factory is an advantage in my opinion, as it makes it easy to prove the engine is not original. In any event, the dealership didn't care about such things then, just compliance with corporate directives and federal law.
Old Dec 10, 2016 | 01:59 PM
PUREW30's Avatar
Interesting
Old Dec 10, 2016 | 04:41 PM
That would seem to be the most likely situation in which the re-stamper would not even care what the stamped number looks like.
It's actually interesting to see a replacement engine that appears to have been stamped according to the guidelines, because so many of them appear not to have been.
Old Dec 10, 2016 | 04:46 PM
My thought exactly.
Old Dec 10, 2016 | 05:25 PM
2blu442's Avatar
Is it this car?
http://www.ebay.com/itm/1971-Oldsmob...m=152350382024
Carb looks like a service replacement carb due to the date code, and I was thinking the 7041253 was the regular 442 manual transmission application but not W30. It has a newer alternator, not an open faced one. The spoiler also has two studs holding it on, I believe factory spoilers had three studs each side. It looks like a really nice car and the build sheet is a super find. But the ad calls it a survivor and says the bolt on's are all original. Then it goes on to say they've located the original heads. So... I have more reservations than just the vin stamped in the block. John
And... I believe the radiator tag is the same one I have on a 4 row radiator. But the top plate on this car isn't a 4 row top plate. It's the non-shroud 2-3 row top plate. The exhaust crossover on the intake look rusty, so its an iron intake.
Old Dec 10, 2016 | 08:38 PM
steverw's Avatar
Possibly formerly a external regulator car? 3 holes in firewall center behind air cleaner, look like where a regulator may have been bolted on. Drivers side trunk dosent fit well, maybe the light but the paint seems to not match in that area as well.
But its a beautiful car, one of my favorite colors on one.
Old Dec 10, 2016 | 08:49 PM
PUREW30's Avatar
Originally Posted by 2blu442
Is it this car?
That's the one. Not sure it's an original 4spd car either as the stamping on the trans is questionable as well. It appears as its double stamped and not very legible. Does appear to be a real W car by the build sheet which is very cool.
Old Dec 12, 2016 | 06:46 AM
Texas442's Avatar
1971 442 conv
This car reminds me of the 71 Bittersweet that used to be on this site few years ago. Here is the old post:
https://classicoldsmobile.com/forums...0-4-speed.html
Old Dec 12, 2016 | 07:14 AM
All cars got those holes punched in the firewall. Besides, the seller has the "W30" broadcast card.
Old Dec 12, 2016 | 11:12 AM
Diego's Avatar
The same guy had an auction for two Cyclone ragtops. I think his narrative for those cars was full of it, but I think he truly believes it.
Old Dec 19, 2016 | 07:23 PM
marxjunk's Avatar
yeah..he's full of himself on the Cyclones...talk about knee deep in bullsh!t...
Old Dec 20, 2016 | 02:34 AM
rcktdoc's Avatar
The 1253 carb is for 71 W30 with double disc option. Greg
Old Dec 20, 2016 | 10:06 AM
anthonyP's Avatar
The factory spoiler had two studs on each side, at least when they were manufactured in 1971.
Old Dec 20, 2016 | 11:10 AM
Rocketguy's Avatar
This is not true. These pics are from a well documented '71 W-30 I restored.
This is the nicest '71 W-30 I've seen at a national meet. Well documented with a window sticker. It did not have regulator holes in the firewall either.
Old Dec 21, 2016 | 07:33 AM
Interesting. My 69 H/O had them punched.
costpenn
Apr 30, 2012 07:40 AM
wagonmaker
Jul 30, 2011 03:13 PM
arodenhiser
Wheels and Tires
Mar 28, 2011 03:48 PM
coltsneckbob
Drivetrain/Differentials
Aug 8, 2009 09:02 PM
blunce
Sep 10, 2007 10:17 AM
