? about spare wheel/tire in 72 W30
The car is a 72 442 W30. Can someone tell me if the spare ss1 wheel/tire originally had the trim ring and center cap installed or is it just a bare ss1 wheel?
Warren
Warren
I can't tell you if this is original or not for sure, but here is the SSI spare from the trunk of my 72 W30. My car has SSIIs on it now when it originally came with SSIs so this could be just one of the original wheels and not actual spare.
If recall correctly there was no trim ring on the spare tire, but the center cap was installed. That is why the hold down bolt went through the rim's lug hole, instead of the hub hole as done with a standard rim.
Check the assembly manual. When I said bare I was referring to the trim ring. I agree that it would have the cap in place. The cap was bolted on. The trim ring just popped off so if you got a flat and changed to the spare, you just swapped the trim ring and you where back in business.
My 1972 442 has the original s.s.2 spare wheel the tire has been replaced the wheel is body color yellow and the only trim on the wheel is the 5 bezels no indentations showing of the center cap being installed
If the spare came without a center cap, Olds would not have needed the special retainer nut that goes in the lug hole instead of the center retainer as on lesser spare wheels. The center cap on SSI wheels requires a socket wrench to remove and replace the bolts on the retainer. This would not have been a required operation to change a tire - otherwise the tool kit would have had to include that wrench.
I sure don't see any trim ring in the stowage decal I posted. I'll ask again. If the center cap was not pre-installed, how was the tire changer supposed to install it with only the tools in the trunk? The trim ring swaps easily. The cap, not so much. Also note that the same decal was used on cars with the all-chrome SSI wheels.
1957OLDSPARTS
November 15th, 2016 04:47 PM
ROCKET VAPOR
June 4th, 2010 09:47 AM
