Red lenses on door panels
If you need to replace them, go to a wrecker. They are also on the 98 regency broughams. You can pick them up for a few bucks in good shape. If you want to spend more....you can get them new from Fusicks for about 30 bucks EACH!!!
BE CAREFUL about the tabs when you take them off. They don't like to be bent more than twice before they snap off. So when you remove them, the next time you should bend them is on the reinstall. If you break the tabs, I guess you could hot glue them to the lower carpet and no one would be the wiser. If you're freshening the interior, dye the lower door carpet to match the floor before you attach the reflector.
If you break yours or need replacements, I've got some I can dig out for you that are in decent shape.
Like the others said, just reflectors.
So what happened? Did you buy some new ones or something? If you still need some decent ones, I can check for you. Don't forget, we were discussing this a little over a year before you found us.
Yup, we are both lucky! Are you looking for a set of these? I can check my stash for you. They will be nice, but not 'perfect'.
KZ442
Dec 11, 2009 07:57 PM
