THrottle cable bushings
Old Oct 25, 2010 | 05:30 AM
Slick68's Avatar
I'm looking for the bushing set listed in the photo attached below. Can anyone tell me where I may find them? They're for a 69 442.
I've checked with Fusick, Inline Tube, Year One, OPG, and Classic Ind. Nobody seems to have them.
Old Oct 25, 2010 | 05:38 AM
Rickman48's Avatar
I try to keep them when I find them, but I've moved twice since I've seen them last.
Try a carb rebuilder in your area, if noone here comes up with one!
The Parts Place has some unusual pieces - check them out, too!
Old Oct 25, 2010 | 05:52 AM
oldsconv's Avatar
USA Parts Supply in VA has them - at least 3 years ago they did - I bought the rubber part and the plastic insert.
Old Oct 25, 2010 | 05:54 AM
oldsconv's Avatar
If you can't find the the rubber pieces, the so called "exact" repro throttle cable you see being sold out there has a smaller attachment area (smaller hole in metal) so it eliminates the need for the rubber bushing and may be a solution for you.
Old Oct 25, 2010 | 06:47 AM
The Chevelle repro houses sell a very similar bushing. This kit is $2.99 from Eckler's Chevelle:
Old Oct 25, 2010 | 07:18 AM
lshlsh2's Avatar
71 cutlass convertible
Welcome, I glad to see your getting some more info for your search.
Larry
Old Oct 25, 2010 | 07:24 AM
Lady72nRob71's Avatar
This looks like the camaro piece I had used from Firewheel classics.
As is, it was too wide for my little cotter pin to go on the throttle shaft, but a sharp razor blade cut it all down from 3/8" wide to 1/4" wide. Flange of both the white part and the black part are on the cotter pin side.
Worked great after then!
Old Oct 25, 2010 | 08:13 PM
70Post's Avatar
Try Supercars Unlimited...they have a narrow rubber grommet and the nylon bushing (bushing was "out of stock" when I ordered a few weeks back but maybe they have them now).
Don't buy the one The Parts Place sells....it's completely wrong and won't work....sent two back last week.
I have the hairpin cotters and the metal backing washer if you can't find any locally.
defiant1
Feb 4, 2020 08:53 PM
dancutlass
Aug 21, 2012 06:26 PM
1k442
Dec 22, 2008 07:24 PM
rayvera
Ninety-Eight
Feb 16, 2007 12:33 PM
rayvera
Feb 4, 2007 07:36 AM
