THrottle cable bushings
Old October 25th, 2010, 05:30 AM
Slick68's Avatar
I'm looking for the bushing set listed in the photo attached below. Can anyone tell me where I may find them? They're for a 69 442.
I've checked with Fusick, Inline Tube, Year One, OPG, and Classic Ind. Nobody seems to have them.
Slick68 is offline
Old October 25th, 2010, 05:38 AM
Rickman48's Avatar
I try to keep them when I find them, but I've moved twice since I've seen them last.
Try a carb rebuilder in your area, if noone here comes up with one!
The Parts Place has some unusual pieces - check them out, too!
Rickman48 is offline
Old October 25th, 2010, 05:52 AM
oldsconv's Avatar
USA Parts Supply in VA has them - at least 3 years ago they did - I bought the rubber part and the plastic insert.
oldsconv is offline
Old October 25th, 2010, 05:54 AM
oldsconv's Avatar
If you can't find the the rubber pieces, the so called "exact" repro throttle cable you see being sold out there has a smaller attachment area (smaller hole in metal) so it eliminates the need for the rubber bushing and may be a solution for you.
oldsconv is offline
Old October 25th, 2010, 06:47 AM
The Chevelle repro houses sell a very similar bushing. This kit is $2.99 from Eckler's Chevelle:
joe_padavano is online now
Old October 25th, 2010, 07:18 AM
71 cutlass convertible
lshlsh2's Avatar
Welcome, I glad to see your getting some more info for your search.
Larry
lshlsh2 is offline
Old October 25th, 2010, 07:24 AM
Lady72nRob71's Avatar
This looks like the camaro piece I had used from Firewheel classics.
As is, it was too wide for my little cotter pin to go on the throttle shaft, but a sharp razor blade cut it all down from 3/8" wide to 1/4" wide. Flange of both the white part and the black part are on the cotter pin side.
Worked great after then!
Lady72nRob71 is offline
Old October 25th, 2010, 08:13 PM
70Post's Avatar
Try Supercars Unlimited...they have a narrow rubber grommet and the nylon bushing (bushing was "out of stock" when I ordered a few weeks back but maybe they have them now).
Don't buy the one The Parts Place sells....it's completely wrong and won't work....sent two back last week.
I have the hairpin cotters and the metal backing washer if you can't find any locally.
70Post is offline
defiant1
February 4th, 2020 08:53 PM
dancutlass
August 21st, 2012 06:26 PM
1k442
December 22nd, 2008 07:24 PM
rayvera
Ninety-Eight
February 16th, 2007 12:33 PM
rayvera
February 4th, 2007 07:36 AM
Quick Reply: THrottle cable bushings
