need help with original rims size 442 1971
Old Sep 1, 2010 | 07:47 PM
saud74's Avatar
Hello,,, I need help with the original rims size 442 1971 holiday coupe ,,
Is it 14" Or 15" ??
please let me know which is the original size for the 1971 442 Holiday Coupe.
Thanks for your help and knowledge!
Old Sep 1, 2010 | 08:42 PM
rcorrigan5's Avatar
Randy C.
14" for 1971.
Randy C.
Old Sep 1, 2010 | 09:28 PM
70Post's Avatar
also...they are 7" wide. There are a lot of similar looking Olds wheels from the pre-70 era that are 6" wide so make sure you get the 7" wheels.
Old Sep 1, 2010 | 09:29 PM
stevengerard's Avatar
yep 14 x 7 do you have SSIs on there or SSIIs or IIIs?
Old Sep 2, 2010 | 09:05 AM
saud74's Avatar
thanks alot for the reply,,
good my rims size 14 x 7
steven ,,, what's (SSIs on there or SSIIs or IIIs) ??
** then what is the correct tire size ,, because most of the tire sizes for rim 14 are small and i'm worry that they will look ugly or small because the body is very big on them.
sorry guys I'm new in this field
Old Sep 2, 2010 | 05:08 PM
BlackGold's Avatar
Using today's metric tire sizes, you should be looking for a tire with about 26.5" diameter and about 225 to 245 mm section width. (The tire diameter is not listed in the metric size marking, but you can find it in the charts provided by the manufacturer, or calculate it yourself.)
Your choices will be very limited for 14" wheels. Much better for 15" wheels, if you're willing to make the switch.
Old Sep 2, 2010 | 06:45 PM
Good advice. A 225/70-14 is about 26.5" in diameter, a 235/70-14 is about 27" in diameter.
Old Sep 2, 2010 | 08:36 PM
mmurphy77's Avatar
I have the original 14x7 SS1 wheels on my car and run P225/70-14 radials and they are as close as you'll probably find in a radial to my original Uniroyal Tiger Paw G70-14 RWL Bias ply.
It's odd, by 1971 pretty much EVERY manufacturer had gone to a 15x7 rim and 60 series tire on all their performance cars EXCEPT Oldsmobile who chose to stick with 14", 70 series tires (except for a few exceptions of course). They have always had better handling packages it's curious why they didn't go with a bigger wheel/tire across the board.
Old Sep 3, 2010 | 06:31 PM
saud74's Avatar
thanks alot for the help
Old Sep 5, 2010 | 05:00 AM
GoodOldsGuy's Avatar
442=A perfect 10
He might want to check out Diamond Back tires www.dbtires.com They have OEM Tires and Radial replacements.
Old Sep 12, 2010 | 04:46 PM
saud74's Avatar
Old Mar 31, 2012 | 07:14 AM
SteveB's Avatar
Wheels for 1971
Hi all,
interesting thread.
I'm not new to Olds but new to the forum. 1971 Cutlass 2dr hardtop coupe.
Wondering if the 14 x 7 is universal for all models in 1971? Considering a set of SSI or SSIIIs.
My car's a driver, not a show car. So wondering if getting an old set and sprucing them up might be better than a new set of repros. Thoughts?
Thanks.
LJA72
Jan 31, 2014 08:02 PM
jim larson
Jun 13, 2013 07:08 PM
grindlecrew
Mar 2, 2013 04:19 PM
CutlassLegend
Care and Appearance
Aug 6, 2011 11:08 PM
