Thermactor hose connection
My '71 442 has the original non-OAI dual snorkel air cleaner (long and short horns). Both horns have vacuum operated Thermactor doors. I have vacuum hoses from both that 'T' together underneath into one hose. Where/what vacuum source does this connect? My asembly manual has info on ALL the other air cleaner types but this one. TIA.
I'll figure it out. I'm going to search TCS and make sure that is all right. It appears so with carb and manifold vacuum plugged in and vacuum advance coming out to distributor. There is a small square plug on the back of the manifold adjacent to the vacuum elbow for the booster. I wonder if that should have been a small port instead of a plug?
