Need help deciphering cowl tag
72 = 1972
3 = GM Division (Oldsmobile)
36 = Cutlass with V8
87 = 2 Door Hardtop Fastback Coupe
Z = Freemont, Ca Assembly Plant
09065?? = Fisher Body Unit #
947 = White in color themed interior with bench front seat
65 = Flame Orange Lower Body Color
65 = Flame Orange Upper Body Color
06B = 2nd week of June 1972 build date
A51 = ?
Don't know the other numbers from what I remember those are unique to Z-plant
A51 = ?
GAOldsman said -A51 = Strato Bucket Seats
stevengerard said -947 = White in color themed interior with bench front seat
I do appreciate the responses BUT which is it bench or buckets ?
White buckets and interior with console including Hurst dual gate shifter.
As I recall, the '72 model year was a little different in what the numbers meant for the trim code. For '72 in many cases, the trim code just meant what color the interior was and then there was an option code to show the front seat type. The trim tag with 947 means white interior, and the A51 code means strato buckets.
Randy C.
Randy C.
Randy C.
Randy C.
The CS could be delivered with EITHER A65 (split bench with armrest) or A51 (Strato Buckets) as standard equipment. Strangely enough even if you got the A51 option it didn't guarantee that you got the D55 console - that was a separate option. I have seen 72 CS's with buckets and column shift as delivered from factory.
There is no "Hardtop Fastback Coupe" at all.
947 is the code for the white interior on this model, both bench *(std) and bucket (optional). Also for the bench (only available) seat in the Cutlass S Sports Coupe. The A51 bucket seat RPO code wouldn't be on the tag if it was standard equipment.
Blackpage, you can look it all up free of charge at Wild About Cars
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn
I have a book (although there are errors in most data compilations) that shows each model year in the era with it broke down between each A body model and B-C body model. That said it states Cutlass S 2 dr Hardtop and Coupe that 947 = White cloth bench seats and 937 = White buckets seats. The very same trim code since '69 for Cutlass and 442 respectfully.
This is the first I've heard of '72 being different as well as an oxymoron or typo if you will on the trim tag. I'd like to see something like maybe a factory bulletin or document stating this. I wonder if '73 was "different" like you say for '72? Being that this was a fairly late build 2nd week of June and roughly 1 - 1 1/2 month(s) away from the '73 model year.
Maybe something to do with Freemont? My '72 was built in Lansing the 1st week of June and has 973 (blue buckets) instead of 983 (blue bench) and A51 (Strato buckets)
But my Fisher Body book states that where his A51 is located on the tag is for "modular seat code GMAD use only" and my A51 is located in the ACC (bottom) where the "modular seat code" is supposed to be.
Further digging suggests
"not to confuse the interior code on the P-O-P with trim code on the Fisher Body Tag. These codes are not the same. The codes on the Fisher Tag indicate a specific interior trim, while those on the P-O-P indicate only the color. A single letter was used on the P-O-P through '68 and because of this confusion, the interior code on the P-O-P was cancelled from '69 - '72."
Is this what you guys were thinking or is there other documentation stating the fact that Randy first pointed out? Not calling anyone out or nothing, just trying to understand why if that was the case then wouldn't my trim tag say 983 as this would have been standard instead of the 973?
Also there was the two digit codes used on the build sheets and window stickers for instance mine says 33 in that area that translates to blue vinyl Strato buckets as to where 43 translates to cloth bench. As to where this one in question would have been 37 for white Strato buckets and 17 for white bench.
Even the '72 Fisher Body Service Manual states specifically "The body number plate identifies the model year, car division, series, style, body assembly plant, body number, trim combination, modular seat code, paint code and date code"
Fig 1-1 shows where his A51 is located "for GMAD use only" as I am leaning toward a change order for this car personally until I see otherwise......
Allan you have the '72 Dealer Album does any of the technical bulletins show anything regarding this issue of a generic color code instead of the standardized trim combination code we are discussing?
Okay so 947 is "generic" for white vinyl for the Cutlass S, whether it is bench or buckets on the Cutlass S. This answers my question to the validity of the subject. Thanks for sharing this info and thank you Randy C for bringing this to light for us.
[QUOTE=wmachine;520349]
I did. I used the Sevice Manual and could not find the info on the interior. Must have overlooked it if it was in there.
Thanks for the info.
Thanks Wmachine. The trim code page was and will be very helpful. Pages from 1964-1973 Trim Codes.pdf (67.2 KB, 3 views)
[QUOTE=Blackpage;520442]
That page was pulled from the 1972 Parts & Accessories catalog, Body Section already online at WAC. I'm starting to post these as "Interior Codes" under "Specifications" there. But I have not got to the '70s yet.
This same info (in greater detail) should be mirrored in the '72 Assembly Manual. The Assembly Manual is the single most comprehensive source of codes and such information, and I would always start there when looking for technical data.
An interesting note though. You know the materials used for the Cutlass, Cutlass S and Cutlass Supreme (vinyl seats - either bench or bucket) was all the same based on the naugahyde and cloth swatches in the guide. However, the code used to describe the trim varies from 900, 910, 920 940 for the base and Cutlass/Cutlass S. The CS uses 950 and 970/978 for the same color. The only thing that appears to be 'generic' is the 2 digit material/color coding that appears in the AM (see Kurts link). They also appear in the 72 SPECS booklet on page dealing with Interior Trim Material Availability. That chart is about as generic but specific as you can get in a small table.
Given that, it would be reasonable to conclude the variations in the 900 numbers listed reflect the stitching and design pattern of the door panels and seats.
So, stating 947 is generic for white vinyl seats for Cutlass S isn't really correct. It is the specific color and pattern for the seats being used for that model. If you looked at the Cutlass or Cutlass Supreme the TR color would change to 917, 927 and 977.
Thanks for your research Al
I said generic because the code 947 means any white in color seat for the Cutlass S in '72 as to where in previous years you were able to decipher the code to place the type and color theme of the interior. As to where in '72 you assume it has standard seats unless it has yet another code for buckets or a more elaborate bench seat such as A51 or A65.
For an example look at the '70 Cutlass S and 442 for white (or ivory rather) it shows 937v and 947v that isn't "generic" at all because 937v = ivory vinyl buckets and 947v = ivory vinyl bench and fairly straight forward.
Oh nevermind It was settled when I saw that pdf last night
jimmer17
May 19th, 2015 05:17 PM
