instrument panel
instrument panel
Where can I find detailed information on removing the instrument panel on a 1966 442? Checked Chilton but the instructions are to vague to me. I need help on removing the light, wiper and ignition switches and the lighter, radio, and heat and cool controls. Thanks for any help. Also on my panel the circular area around the lighter is chrome, on a used panel I bought the area is green plastic, why the difference?
It is better to remove dash pad and instrument panel as a unit. Light switch has a button on the bottom. Push it and ****/rod assemble will come out then unscrew escushion and it comes out. Lighter socket unscrews from behind. Temp controls are bolted from behind. You need to remove cables from devices they operate. Ignition switch is a pain. You need to have key in it and turn to Acc. Then put a pin in the hole in the front and play with it wiggling key and lock cylinder will come out.
I just ordered a complete set of shop manuals for my '69 Cutlass from Detroit Iron. They were recommended elsewhere on this forum. I just checked and they have one for your '66 as well. I bought mine through http://www.rockauto.com
Found this on Ebay. Can someone tell me if this is what I need?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
From: Orion Township Michigan 30 Miles North of the Murder City
Hey Tom
With this restored IP that I going to bring you ..I will give you my version of removing the IP.It goes step by step.And if you have any problems I am a phone call away.In fact I will send it to you Email address later today.I am by no means an expert at taking these things out.I have revied and replaced 10 to 20 of them..Mine maybe 9 times.
Lets just say ...I know the neighborhood.
Talk to you soon.
Ron
P.S Your dash will be the last one I restore for the season.
I am going to take a break and enjoy my car..
Talk to you soon.
Ron
Also, go to www.wildaboutcars.com and join (it's free), they have the Chassis Service Manual and the Assembly Manual for your '66 online (and they're free!).
I would go ahead and buy the hard copy from eBay though. It is a decent price and it is nice to have one that's not electronic as it makes it easier to quickly reference something. Don't worry that it seems to be falling apart, they all do that and fairly quickly too.
Curses! I bought that $25 CD with the manuals, and they are right there on www.wildaboutcars.com
After all the reading I have been doing concerning the removal of the instrument panel it seems as though the dash pad should be removed and the panel comes with it. Is that correct? This may sound like a stupid question but I would like to know.
Definately pull it all out as one unit. Some people have even left everything connected and pulled the unit after disconnecting the harness with fusebox ( disconnect speedo cable, remove radio ***** and nuts etc.). I do have a suggestion though. Once you have removed all the mounting nuts, pull the unit forward about 4 inches and reach behind disconnect the four screws holding the heater controls in place. It's much easier than removing the cables and then hooking them backup properly.
Tom
I will have your dash ready in about 3 weeks and I am planning a trip to Cleveland.
Dont get worried .We will get throught this.I can help..
It will take me 4 or 5 hours ..
Ron
Ron
