Carter Thermoquad on 66 442 - original?
Old May 26, 2011 | 09:05 AM
halffast's Avatar
Member
My 66 442 has a Carter Thermoquad on the original 400 engine. I've always thought that it was probably a replacement for the original Rochester Quadrajet sometime in the late 60's to early 70's. Is it possible that the Carter could be original? I've heard stories that because of the high demand for the quadrajets at the time that some Carter thermoquads were used. Any input would be appreciated. Thanks -
Old May 26, 2011 | 09:32 AM
Oldsmaniac's Avatar
I would say your car came for sure with a quadrajet and I am not sure when the plastic bodied thermoquad was invented but I would say for sure it was owner replaced.
Old May 26, 2011 | 09:50 AM
rocketraider's Avatar
Oldsdruid
You sure it's not a Carter QuadraJet? Carter did supply them to GM, but most I've seen were on Pontiacs.
It would not be unusual to see a 1966 QJet replaced with something else. That first-year design had some teething problems. They had a strange diaphram needle and seat and were quite prone to well plug leakage.
Old May 26, 2011 | 10:39 AM
firefrost gold's Avatar
carter afb Was used on pontiac till 67 then went to the q jet i would suspect olds would be the same way.
Old May 26, 2011 | 10:45 AM
Oldsmaniac's Avatar
The afb is not a spreadbore like the thermoquad. Before 66 olds used the Rochester 4 Jet with the Quadrajet being introduced for the 66 Model year. The intakes would be different as well.
Old May 26, 2011 | 11:01 AM
halffast's Avatar
Member
My apologies to all, it is a quadrajet by Carter licensed by GM. I must have had a senior moment. So my question should have been, Could they have used the quadrajet by Carter on my 442 in 66'. In reading rocketraiders response, I guess it could have been possible.
Old May 26, 2011 | 01:34 PM
I would have as stated almost bet on a afb thats why im not a gambling man
thats why i read most posts thanks.
Old May 26, 2011 | 02:10 PM
Check the number on the carb to see if it's correct for a 1966. And although we've cleared up the confusion, note that the Carter Thermoquad didn't even exist in 1966.
Old May 26, 2011 | 02:29 PM
halffast's Avatar
Member
Thanks Joe. I will research the number to see if it's correct for a 66'.
67Olds442X2
Feb 11, 2012 01:05 PM
74 Omega
Feb 6, 2012 05:40 PM
59-59-59
Jun 3, 2010 08:43 PM
Oldsmobomb
Aug 2, 2009 08:02 PM
Oldsproject
May 10, 2007 06:03 PM
