68 442 engine rebuild options
Old Jan 31, 2012 | 08:03 AM
442craig's Avatar
Hi Guys,
New to the forum! I am restoring a 68 442 convert. I am planning to pull the engine (car was restored in '89) It runs fun, just want to make sure everything is good. I was considering "heating it up" a little. The car is going to stay relatively stock. Any suggestions on cams, pistons head work, etc. What kind of HP bumps can I expect without going to crazy?
Thanks,
Craig
Old Jan 31, 2012 | 09:20 AM
allyolds68's Avatar
Originally Posted by 442craig
Hi Guys,
Thanks,
Craig
Drop a $100- $200 for a 455 block and reuse heads and your internals
Old Jan 31, 2012 | 12:50 PM
MX442's Avatar
Wouldn't those pistons rattle a bit?
Old Jan 31, 2012 | 12:56 PM
svnt442's Avatar
Originally Posted by mx442
wouldn't those pistons rattle a bit?
lol!!
Old Jan 31, 2012 | 01:27 PM
allyolds68's Avatar
Any suggestions on cams, pistons, head work, etc.?
Thanks,
Craig
OK, I suggest new pistons as well
Old Feb 1, 2012 | 07:44 AM
Wraythe's Avatar
If your engine is numbers matching to your 442, I would save it and find a 455ci to rebuild. It's a win-win solution
I hope this helps.
Old Feb 1, 2012 | 08:15 AM
442craig's Avatar
Thanks for the replies! It is a numbers matching car. What are the benefits of a 455 block? (besides the cubes and hp increase) how much of the 400 stuff will transfer?
Thanks,
Craig
Old Feb 1, 2012 | 08:31 AM
allyolds68's Avatar
Thanks,
Craig
I went through the same thing as you. I didn't have a numbers matching block but I had (and still have) a "correct" 400G block. Everything can be reused except the pistons, which, even if you rebuilt your current engine, you'd have to get anyway. So basically your only cost is the block. If your car is a standard you should limit your search to blocks that have the threaded boss for the Z-bar, which are 68-74 (?) 455's
Old Feb 1, 2012 | 11:34 AM
442craig's Avatar
Thanks Mike,
I was looking at your photos yesterday and getting inspired! I have been torn on how stock I want to keep it. It is a driving investment. I want to keep it at top dollar just in case I need to sell it. Numbers matching seems to be the best way to keep your investment.
Craig
Old Feb 3, 2012 | 05:53 PM
Wraythe's Avatar
Benefits of 455ci are: HP & Torque increase, availability & cost (cheapest to rebuild). Purchase a long block, don't rape your current engine for parts or you will regret it
Funkwagon455
Aug 23, 2014 03:17 PM
Jul 5, 2012 09:34 AM
Steve Wike
Mar 11, 2012 11:47 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
