'66 442 validation
Obviously you need to look for things like the correct E-block 400 with B heads, the correct boxed lower control arms and sway bar, the 442 grille and emblems, the 442 taillights, and the vents in the front fenders, but all of that is bolt-on and will not prove anything.
Check the rear end upper control arms. (rear of frame cross-member) There should be 4 bolt holes on a true 442 frame. The Cutlass only has 1 hole. This is true for a 65 and should be for 66 and 67. There is an explaination posted on this site:
http://442restoration.homestead.com/65specs.html
Hope this helps.
Hope this helps.
