what motor oil to run
I have a 383 with a flat tappet cam I heard you need to run oil with zinc in it would redline oil be ok I do not want my cam to go flat does anybody know what oil to use thanks
I just rebuilt with a Melling stock camshaft. The instructions with the cam recommended Shell Rotella, among others. Says modern oils are formulated for roller lifters and do not contain enough anti-wear additive. Some thing I did not realize. Maybe I should be using it in all my old engines. I do use it in my diesels.
I've been told to use Shell Rotella 15w40 (conventional or synthetic.) It is high enough in zinc and has a lot of detergents in it. It's a high quality diesel oil and can be used in a car without a catalytic converter.
I like that it's not too expensive (Lucas oil and race oils here are super pricey), easy to find, and even our most famous retailer here (Canadian Tire) re-badges the fleet version of the stuff and sells it cheap, though it has fewer detergents, supposedly.
Alot guys I know run Brad Penn they say the companys has been around for 30years and there oil has more zinc in it for flat tappet cams. alot of oils are starting to put less zinc in there oils. newer cars really don't need zinc zzdp
i heard the zinc plugs the cat converters
Do u mean Chevy engine? why is that to bad when I bought is car it already had a chevy 350 in it but when I put 383 in with the. Trick flow heads man those heads are bang for the Buck heads.I felt the horse power difference
shamusj
Mar 21, 2023 02:12 PM
shamusj
Mar 4, 2016 06:48 AM
