what motor oil to run
Old Mar 27, 2012 | 11:32 AM
gabe442's Avatar
I have a 383 with a flat tappet cam I heard you need to run oil with zinc in it would redline oil be ok I do not want my cam to go flat does anybody know what oil to use thanks
Old Mar 27, 2012 | 12:17 PM
Yes!
Old Mar 27, 2012 | 09:11 PM
gabe442's Avatar
What oil would you get redline or Brad Penn?
Old Mar 28, 2012 | 06:56 AM
Either is fine!
Old Mar 31, 2012 | 01:27 PM
Al Graaf's Avatar
Formerly "Shimmer"
Have heard and seen ads for the Brad Penn oil. Who are they and what is so unique to their oil. I'm just about ready to "give birth" to my 455 and concerned about oils. Thanks,
Old Mar 31, 2012 | 06:43 PM
m371961's Avatar
I just rebuilt with a Melling stock camshaft. The instructions with the cam recommended Shell Rotella, among others. Says modern oils are formulated for roller lifters and do not contain enough anti-wear additive. Some thing I did not realize. Maybe I should be using it in all my old engines. I do use it in my diesels.
Old Mar 31, 2012 | 07:14 PM
Bobert's Avatar
Running Brad Penn break in oil in a mild cammed 303 bottom end with 324 heads, carb etc.
Old Apr 1, 2012 | 12:29 PM
sicky olds's Avatar
NôôB
myself and danny use valvoline vr-1 that you can get from NAPA. it has the zinc added already as well
Old Apr 2, 2012 | 11:54 AM
67 Olds 442's Avatar
After some research I went with Mobil Delvac 1300 15w-40. From what I've read, lots of the other brands lowered their zddp, ie Shell Rotella T.
Old Apr 2, 2012 | 12:06 PM
justinj's Avatar
I've been told to use Shell Rotella 15w40 (conventional or synthetic.) It is high enough in zinc and has a lot of detergents in it. It's a high quality diesel oil and can be used in a car without a catalytic converter.
I like that it's not too expensive (Lucas oil and race oils here are super pricey), easy to find, and even our most famous retailer here (Canadian Tire) re-badges the fleet version of the stuff and sells it cheap, though it has fewer detergents, supposedly.
Old Apr 3, 2012 | 06:29 PM
gabe442's Avatar
Alot guys I know run Brad Penn they say the companys has been around for 30years and there oil has more zinc in it for flat tappet cams. alot of oils are starting to put less zinc in there oils. newer cars really don't need zinc zzdp
Old May 23, 2012 | 03:57 PM
archeryshooter's Avatar
Tony
i heard the zinc plugs the cat converters
Old May 23, 2012 | 05:09 PM
70olds455's Avatar
I use valvoline VR1 racing oil in my 70 cutlass with a built 455.
Old May 23, 2012 | 07:15 PM
gabe442's Avatar
I heard the same thing about the zinc plugging up the cats but my car is a 70 I got no cats so I'm good.the Brad Penn oil is ment for older cars
Old May 23, 2012 | 07:29 PM
And this concerns you because...?
Old May 24, 2012 | 05:30 PM
ziff396's Avatar
Exactly. I run 10-40 Royal Purple in mine. Expensive - Yes. I got it this year from Advance Auto for 1/2 off on a sale. I also still add a (little) zinc additive to it just because.
Old May 24, 2012 | 07:44 PM
37OldsCoupe's Avatar
Run any oil you want and just add the additive.
Rick
Old May 24, 2012 | 09:39 PM
64Rocket's Avatar
Isn't that a chubby engine?
If so, that's too bad.
Gene
Old May 25, 2012 | 06:27 AM
gabe442's Avatar
Gene
Do u mean Chevy engine? why is that to bad when I bought is car it already had a chevy 350 in it but when I put 383 in with the. Trick flow heads man those heads are bang for the Buck heads.I felt the horse power difference
shamusj
Mar 21, 2023 02:12 PM
shamusj
Mar 4, 2016 06:48 AM
Alex72cutty
18
Jul 30, 2014 08:25 PM
krashx7
Dec 19, 2012 01:43 PM
