70/71 power window door panels
Can some one confirm that the holes for the cranks in manual window door panels can be altered and accomodate power window switches without leaving evidence of not being factory installed? In other words, they end up in the same location as they would have been from the factory?
With some patience & cutting tools(dremel,scalpel,box knife), you can alter tne crank holes for the power window switches & it will look like a factory install. There are notches on the back of the panel that show where to cut.
Thanks, I'm glad to hear that. It's nice to know I can alter the original panels and not have to replace them.
Here's a pic of the metal retaining tabs that RocketBrian is referring to. These have tabs that bend over the backside of the doorpanel boards and the chrome "button" assemblies slip into these.
These would also serve as a template of sorts to guide you while cutting...always err on the side of slightly small and work your way up to the final size if possible.
eudaman
May 19, 2013 05:30 PM
69442murph
Feb 19, 2013 06:55 PM
