'70 442 Dome Light Fixture
Old Jun 29, 2012 | 03:25 PM
DRXOLDS's Avatar
Has anyone bought a new dome light fixture from opgi P.N. PZ200023?
I bought one a year ago and the complete base was chrome plated (on plastic). Well this won't work because the chrome plating conducts electricty and well the light is on all the time and the outside of the fixture is + 12V. (With a volt meter).
If you look at the opgi web (today) same P.N. as above you will see the area for the (2) contacts and bulb is white plastic....just like the O.E.M. . They have about 200 on backorder.
Just curious...... and if you have one that has a completely chromed base don't use it......or as I was suggested just file it off where needed ..look at the base and you will see that would be a trick.
Old Jun 29, 2012 | 04:18 PM
couldn't find it on their site using that number...did they pull it off the market?
Old Jun 29, 2012 | 05:50 PM
DRXOLDS's Avatar
'70 Olds Dome Light
Hi,
Go on the opgi web site select car '70 Olds 442. Under Interior Trim you will find it (manual search 1st page bottom lft corner) Your right searching the number = no results.
Search for DLK006. This is the whole kit.
This gives you the base, lense,new leads and maybe the bulb they could not tell me if the bulb was included. It's in the picture but not the "kit" description. They are back ordered also.
Don't get me wrong they look nice, if the base was plated in only the correct areas.....I never new plastic "chrome" could conduct juice !
Boldsmobile
Sep 13, 2010 08:34 PM
68Tom
Mar 28, 2009 07:11 AM
68Tom
Mar 26, 2009 07:56 PM
gerlof_1
Jan 24, 2008 12:19 AM
HAFROD
Jan 22, 2008 05:12 AM
