How can i decode this
Old Oct 29, 2014 | 11:21 AM
dedeaux89's Avatar
I'm trying to figure out what I'm working with in plans on bringing it back to original. I'd like to learn more about this cars history as well. And where are some good places to buy parts. Any input appreciated in advanced and if there are certain do's and don'ts let me know so I dont make the same mistakes
Old Oct 29, 2014 | 11:24 AM
Diego's Avatar
Probably would help to know what car you're talking about.
Old Oct 29, 2014 | 11:25 AM
dedeaux89's Avatar
Sorry clicked close window before attachment had finished uploading
Old Oct 29, 2014 | 12:02 PM
jaunty75's Avatar
I make that to be a 1971 442 2-door hardtop (34487), built at Lansing in the first week of March 1971 (03A). Lower body color lime green (43), upper body or vinyl roof color black (B), jade green vinyl bucket seats (932), and heavy duty rear floor mats (B35).
How close is this to what you have?
Old Oct 29, 2014 | 01:20 PM
dedeaux89's Avatar
I can tell it used to be green. It is a 71 hard top black vinyl its got black interior. no floor mats. Is this car special or rare at all?
Old Oct 29, 2014 | 01:39 PM
jaunty75's Avatar
Floor mats or anything not stuck down can easily disappear after 43 years.
As far as rare or special? The 442 guys can likely give you a better answer, but it doesn't sound any more or less special than any other '71 442. The cowl tag is actually sparse, so there weren't that many Fisher Body-installed options on the car. Only the B35 floor mats. No tinted windshield, drip rails, power antenna, deluxe seat belts, or any of several dozen other possibilities.
It's no more rare than any other '71 442, and '71 442's are certainly around.
One thing is that 1971 was the last year that the 442 was it's own separate series in the Olds lineup, so that makes it somewhat special. From 1964 through 1967, and from 1972 and later, the 442 was an option package on the Cutlass lines. Four four model years, from '68 through '71, it was its own series.
It will always have value because it's a 442, regardless of exactly which options are on it. You say you want to bring it back to original, which is an admirable goal. What does it need? We'd love to see some photos.
Old Oct 29, 2014 | 02:52 PM
Mr Shifty Sidney's Avatar
I think that is B85 instead of B35. B85 is exterior belt moulding, B33 is rear floor mats according to the Inspectors guide for 71.
Don W
Old Oct 29, 2014 | 02:57 PM
jaunty75's Avatar
I think you're right.
Old Oct 29, 2014 | 03:20 PM
vette442's Avatar
None of this stuff is ever on the cowl tag (except maybe the drip rail trim), even on the highest optioned '71 442 ever built.
Terry
Old Oct 29, 2014 | 03:32 PM
rcorrigan5's Avatar
Randy C.
...and it was assembled at the Lansing MI plant (LAN) in March (03), first week of that month (A), 1971.
Randy C.
Old Oct 29, 2014 | 05:08 PM
dedeaux89's Avatar
Pics
Old Oct 30, 2014 | 09:26 AM
rcorrigan5's Avatar
Randy C.
Good places to buy parts:
On this site if you are looking for original replacement parts - there are a lot of good and reliable vendors right here.
If you are looking for reproduction parts, try Fusick (www.Fusick.com) in Connecticut. They have their catalog on their web site. They are very reliable as well and they know Oldsmobiles. Another great source (mechanical parts only) is Supercars Unlimited, near Portland Oregon (www.supercarsunlimited.com). Their catalog is also on-line and they do have some used original parts.
As well, think about joining the Oldsmobile Club of America. They have a monthly publication called Journey With Olds that advertises parts and sources for parts. Likewise, if you have a local OCA chapter, join them, too. Most local chapters have monthly newsletters that advertise vendors and parts.
Do's and Don'ts:
This can boil down a lot to personal desires. I'm more of a purist so, when I restored my '68, I wanted all the parts to be as original as possible, complete with correct part numbers and, if those parts had build dates stamped into them, a date that would be consistent with the build date of the car. I had to find a carburetor, distributor, coil, alternator, starter and water pump to make my original engine complete and I found them in the sources I mentioned above. When I had the car painted, I went with the original color, which isn't too exciting (white with black interior) - the Olds red for 1968 would have looked a lot better - but I just like what is on the trim tag to match what I see on the car.
Another thing I did was add some options that weren't originally on the car. However, any option I added didn't involve making changes to any metal in the car - they were simply "bolt on" options. I figured it was OK just as long as I could convert it back to original if needed (I have the original window sticker). For instance, I changed the original AM radio (front speaker only) to a factory AM-FM radio with a rear speaker. I also changed the idiot lights to factory gauges. I swapped out the standard speedometer for a "speedminder" speedometer and I removed the blank pod in the dash and installed a tic-toc-tac. And I removed the points and condenser and installed a Pertronix ignition in the distributor.
I believe you will get a lot of variance on "do's and don'ts", though. The bottom line is that it's your car and you need to make it the way you want it to be. The beauty of this site is that you can get all kinds of valuable input as you make your car the way you want it to be. And, there are lots of vendors here that will have the parts you need as you progress towards the car you want. As far as I am concerned, this is the best web site going for Olds enthusiasts and I've learned so much from the people here who are what I consider "the experts" on Oldsmobiles!
Randy C.
Old Oct 30, 2014 | 10:24 AM
Is that a glasstek hood? Not all 442's came from the factory with the W25 hood, but it does help make the car look more aggressive. If you want to complete that look, you'll also need to add dual exhaust and cutout rear bumper, and do the proper side/deck lid stripes.
Just an add on to Randy's sourcing info? Here's a thread that discusses who the good vendors are (and the ones to stay away from)
Where is the best place to buy "correct" replacement Oldsmobile parts?
Old Oct 30, 2014 | 12:30 PM
dedeaux89's Avatar
its fiberglass. I'm gonna put the original on soon as I can go pick it up from the guy that has it
=Allan R;758962]Is that a glasstek hood? Not all 442's came from the factory with the W25 hood, but it does help make the car look more aggressive. If you want to complete that look, you'll also need to add dual exhaust and cutout rear bumper, and do the proper side/deck lid stripes.
Where is the best place to buy "correct" replacement Oldsmobile parts?[/QUOTE]
Old Oct 30, 2014 | 12:41 PM
Don't forget to get the underhood OAI components if he still has those.
tyler_s
Sep 20, 2010 05:25 PM
krissiibabii
Aug 4, 2010 03:26 PM
ent72olds
Jun 22, 2009 07:53 PM
greghsc
Aug 18, 2008 12:24 PM
Retrorocket88
Apr 25, 2007 12:06 PM
