Jack stowage
Old Jan 29, 2015 | 12:40 AM
kansjfr's Avatar
Jack stowage
Does anyone have any pictures/diagrams of how the jack/spare tire is supposed to be stored/clamped down in the trunk? Steel wheel, by the way.
Old Jan 29, 2015 | 02:39 AM
ignachuck's Avatar
Frank Ignachuck
What year?
Old Jan 29, 2015 | 05:00 AM
Old Feb 1, 2015 | 01:01 AM
kansjfr's Avatar
1968. Sometimes, I'm such an idiot. AFTER (instead of before, like I should have) posting this, I found that this topic has been hashed out previously, and the most helpful info was in a previous thread noting that the assembly manual had a diagram on jack placement in the trunk, and I got it all battened down. The assembly manual is helpful, but I have a hard time finding the info I'm looking for at the time.
Old Feb 1, 2015 | 06:00 AM
allyolds68's Avatar
It takes some getting used to but once you figure out there's no better place for information. The manual is generally arranged in the order that the car was assembled. I usually look at the index first and that gets me to the section or two I need. After using it for a while you'll start to memorize the sections and won't need the index.
Old Feb 1, 2015 | 09:42 AM
navvet's Avatar
Be nice if there was a post or web page showing all olds trunk/ Jack layout. My 1964 88 does have a sticker so it was going to car shows and google photos to find layout information. When I got car it had no jack no tire.
Old Feb 1, 2015 | 09:50 AM
1970cs's Avatar
Lansing built
http://www.drdecal.com/viewcategory.php?groupid=62
Pat
Old Feb 1, 2015 | 10:00 AM
Which is exactly where the image I posted is linked from.
Old Feb 1, 2015 | 10:15 AM
1970cs's Avatar
Lansing built
Eric, great minds think alike!
I should have quoted navyvet when I posted
Pat
Old Feb 1, 2015 | 10:28 AM
Yeah, Mark has really good stuff, and posts legible facsimiles in his catalogue, so it's the best place to go to answer questions like this.
Old Feb 1, 2015 | 10:35 AM
Octania's Avatar
I went to my Excel database
ctrl-F for find
"jack"
5th hit or so says
Pg 571 CD PNMamual
open the cd pn manual and tell it to go to pg 571, voila there ye are.
another option.
Old Feb 1, 2015 | 01:23 PM
Side question, were the decals different for SSI/II over steelies?
Old Feb 1, 2015 | 01:28 PM
1970cs's Avatar
Lansing built
Yep!
Pat
Old Feb 1, 2015 | 01:55 PM
Most notably, the jack handle clipped onto the upper inside trunk lip, jack base is under the tire, and the J hook is shorter with a special nut (instead of wing nut) that holds the tire in place. Note: Tire is also stored upside right instead of upside down.
Old Feb 1, 2015 | 02:04 PM
Good info. I don't think my old heap is an SSI car, but it came to me with SSIs on it. I believe the jack sticker is there (and is for normal wheels), but the clips for the wrench are not there, nor is any jack equipment. I suppose, since I have some nice SSIs and am adding every option under the sun to the car, might as well make it SSI jack stowage compliant.
rcktdoc
Jan 26, 2016 05:02 AM
customcruiserfan
Mar 9, 2014 06:34 PM
NDERISE
Mar 10, 2013 09:23 PM
65cutty
Jan 14, 2009 04:37 PM
kaz442
Nov 26, 2008 02:43 PM
