tune up specs
Old Nov 10, 2014 | 11:20 AM
1965W29's Avatar
tune up specs
Where can I find the tune up specifications for 1965 442 400.
Steve
Old Nov 10, 2014 | 01:20 PM
m371961's Avatar
Why not the Oldsmobile CSM for the year of the engine?
Old Nov 10, 2014 | 01:37 PM
These will get you close:
http://www.tpocr.com/olds1.html
Old Nov 10, 2014 | 01:40 PM
m371961's Avatar
Excuse my ignorance, my 65 CSM doesn't show specs for the 400.
Old Nov 10, 2014 | 02:52 PM
1965W29's Avatar
Tune Specs
Thanks for the info, poor mans was right on. I was going to use the 425 specs which are the same except as I see it the timing. Hope to help with bog on acceleration. Next vacuum advance or carb rebuild!!!!
Steve
Old Nov 10, 2014 | 03:59 PM
Well, you are quite right. I couldn't find it either, just 225, 330, and 425.
The carburetor adjustments just generalize for 2GC and 4GC.
So, since they didn't print the 400 information in the September, '64 manual, where did they print it?
Old Nov 10, 2014 | 04:02 PM
If your running an HEI, those specs won't work. Either way, I would set total timing as close to 34-36 as I could get it and let the initial wind up where ever it winds up. Then limit the total with vacuum to around 50.
Read this ( these principles are the same for all v8's):
http://www.corvette-restoration.com/.../Timing101.pdf
and this:
http://www.badasscars.com/index.cfm/...d=76/prd76.htm
Old Nov 10, 2014 | 04:11 PM
1965W29's Avatar
My 400 is totally stock with the 4GC carb.
Old Nov 10, 2014 | 04:29 PM
Read up on performance timing. You'll be pleasantly surprised that stock engines benefit from additional advance.
This is pretty good reading and pretty informative:
http://oldsjunction.classicoldsmobil...n.htm#Ignition
Old Nov 10, 2014 | 05:24 PM
m371961's Avatar
Not to hi-jack, but teach me sometin. Was the 400 a mid year thing?
To the OP- Is you accelerator pump working fully?
Old Nov 10, 2014 | 05:42 PM
The 400 was new for 65 as the 64 was a 330.
Old Nov 11, 2014 | 02:37 PM
1965W29's Avatar
Thanks to all for the info on 400 specs, dwell originally was 19 , set the dwell at 30, new points, condenser, new vacuum advance and new distributor advance kit. Acceleration greatly improved, still a little bog. Rebuilding the 4GS next, as I noticed the accelerator pump leaking a little.
Steve
valhalla
Mar 21, 2011 11:47 PM
Brizio
Feb 15, 2009 11:52 AM
gypsy66delta
Aug 19, 2008 12:54 PM
southcarolina803
Jul 8, 2008 07:37 PM
RussTad
Sep 14, 2006 04:09 PM
