upper radiator top
Old Aug 16, 2014 | 03:22 PM
w30hurstolds's Avatar
upper radiator top
just bought a w-30 with 3;42 gears code on build sheet is coded fe do all w-30 come with a 4 core or can you get a 3 core.
Old Aug 17, 2014 | 09:38 PM
jstrits's Avatar
Someone added a shroud, your car came with the non-shroud top plate. didn't you post this question elsewhere before?
Old Aug 18, 2014 | 12:59 AM
hurst68olds's Avatar
I was the one who asked the question in the "for sale" thread.
per the posted documentation (in the other thread) the car is coded for "FE" - radiator & "V02" - heavy duty radiator 2.00" core
per the assembly manual:
sect. 11 page 50: 4400 series w/V02 = radiator "FE" #3014745 (1 of 5 radiators for the 442) * "V02" MANDATORY w/3.42 axle ratio (NA with A/C-C60 or HD Cooling-Y72).
sect. 11 page 52: 4400 series (NO Radiator Upper Baffle Assembly indicated for "V02"), but there are only 2 shown for 442 (STD & V01, C60, Y72).
sect. 11 page 108: shows upper radiator hose attached to Radiator Upper Baffle (for V8 w/o V01, C60, Y72) & NO shroud.
sect. 11 page 110: shows shroud with V8 with V01, C60, Y72 (upper radiator hose attached to shroud).
IMO the assembly manual shows the "FA", "FB", & "FE" radiators have narrow tanks (for 3 row cores) & the "EC" & "ED" radiators have the wide tanks (4-row cores).
Of the '70 442s currently on eBay only two have a "4-core" top plate.
Old Aug 18, 2014 | 01:12 AM
OP: What's holding the top of the shroud to the top plate and/or radiator?
Alex72cutty
Apr 21, 2015 10:30 AM
w-30dreamin
Mar 29, 2010 06:32 PM
Dan Wirth
Oct 8, 2009 11:56 AM
jensenracing77
Jul 22, 2009 04:55 PM
