Ram Air hood lock will not release
Old Oct 17, 2024 | 10:27 AM
Kdavis001's Avatar
What can I do to get this to pop up?
I have pushed down on hood while turning ****, pulled hood up while turning, it just won’t pop up.
Frustrated.
Old Oct 17, 2024 | 12:25 PM
You probably have a drifted pin. Which side is it on?
This is A Bitch to fix. The roll pin has possibly drifted off center. There's a method to snap it and break it. It is also possible to reach up with the world's smallest channel locks, or maybe even by hand, and push the pin back centered. Helps to have an assistant push down and rotate the assembly as needed.
Old Oct 17, 2024 | 12:56 PM
Kdavis001's Avatar
Old Oct 17, 2024 | 12:58 PM
Kdavis001's Avatar
Thank you Koda.
It is on the drivers side. I did try to see if crawling under the car and reaching up was an option, but there is way too much in the way. . I keep going into my garage and turning the lock in hopes it manically pops up… no luck so far.
Old Oct 17, 2024 | 01:15 PM
VC455's Avatar
Barely Registered
When I had that problem, I carved small wood blocks to fit on the sides of the raised portion of the hood lock handle. I used large vice grips on the wood blocks and forceably turned the lock. This bent the pin and released the hood. (I used bits of rubber glove between the blocks and the handle to be sure there was no slippage.)
I then replaced the pin. You can be sure that I used thread locker on the new pin.
Good luck whichever method you choose!
Last edited by VC455; Oct 17, 2024 at 01:18 PM. Reason: Added way to keep blocks in place
Old Oct 17, 2024 | 01:36 PM
Originally Posted by Kdavis001
Thank you Koda.
A friend and I did what I suggest on my car on the left side. It is possible.
Old Oct 17, 2024 | 02:13 PM
Kdavis001's Avatar
I just got it opened. I placed a towel over the lock and twisted with vice grips and was able to break the pin which released it.
Spoiler
Thank you all for your help!
Old Oct 17, 2024 | 04:06 PM
bccan's Avatar
Search the subject, it has been discussed many times and there are a lot of cat skinning methods among the membership.
Gene kerr
Oct 2, 2021 10:46 AM
Hdmike444
Feb 5, 2021 10:13 AM
Mar 26, 2019 04:04 PM
huskalade
May 25, 2014 06:43 PM
