68 442 coupe vinyl top stud template/measurements for spacing
Does anyone have a diagram or measurements showing where the studs/holes for the vinyl top molding go on the upper trunk lid on a 68 442? Thanks!
Thank you sir! My paint and body guy may still have the old trunk lid to use as a template but if you get a chance to send me anything I’d appreciate it. I’m in Indian Land actually. Where are you in your restoration on your car?
Hi Kcastl03,
Do you have the metal simulated vinyl grain trim for that spot?
Are the holes drilled in the rear quarters for the L shaped cast chrome peak ends?
These 3 pieces mounted to the car will give you a good idea where the holes go.
Steve
Steve
KCastl03
Apr 21, 2024 03:34 PM
