68 442 coupe vinyl top stud template/measurements for spacing
Old Jul 31, 2025 | 09:09 AM
KCastl03's Avatar
Does anyone have a diagram or measurements showing where the studs/holes for the vinyl top molding go on the upper trunk lid on a 68 442? Thanks!
Old Jul 31, 2025 | 05:44 PM
69shawn's Avatar
I can help. I’m working on the same thing. I’m in Rock Hill. I’ll get you something over the weekend. Or, you can stop by.
Old Jul 31, 2025 | 05:57 PM
KCastl03's Avatar
Thank you sir! My paint and body guy may still have the old trunk lid to use as a template but if you get a chance to send me anything I’d appreciate it. I’m in Indian Land actually. Where are you in your restoration on your car?
Old Jul 31, 2025 | 07:06 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Hi Kcastl03,
Do you have the metal simulated vinyl grain trim for that spot?
Are the holes drilled in the rear quarters for the L shaped cast chrome peak ends?
These 3 pieces mounted to the car will give you a good idea where the holes go.
Steve
Old Jul 31, 2025 | 07:39 PM
KCastl03's Avatar
All the other parts of the car are drilled and setup for the roof I just had to get a new trunk lid. I do have the simulated vinyl metal strip as well.
Old Jul 31, 2025 | 09:04 PM
You should be able to use the metal trim as the template for the stainless trim.
Old Aug 1, 2025 | 05:19 PM
69shawn's Avatar
1.25” down from the top edge of trunk lid. You can use the simulated vinyl piece to line up the 6 studs and 2 threaded studs.
KCastl03
Apr 21, 2024 03:34 PM
stcsawdust
Body work
May 12, 2021 08:29 PM
Billyaxe
Nov 23, 2020 10:06 AM
Billyaxe
Body work
22
Mar 20, 2019 07:44 PM
Rusty Boltz
Jun 2, 2018 07:07 AM
